Sponsored by: Real Truck
test mode.
Old Feb 24, 2009 | 02:59 PM
firemanpat29's Avatar
firemanpat29
test mode.
I have searched and cant find the link that was here on what all the steps are and what normal readings are when you hold down the trip reset button then start the truck. The odometer says TEST then gauge sweep, ect. Does any body have the link?
Old Feb 24, 2009 | 04:08 PM
ReAX's Avatar
ReAX
This is the one I reference for error codes, Mustangworld HEC Instrument Cluster Diagnostics
Old Feb 24, 2009 | 04:13 PM
firemanpat29
thanks thats close but the newer super dutys have more info.
Old Feb 24, 2009 | 04:41 PM
ReAX's Avatar
ReAX
Do you have a different HEC module? That should be the same info for all 2002 upto 2005 with the CAN network. I was under the impression the CAN network screwed up the test mode. If you find a better website, please post it.
Old Feb 25, 2009 | 08:26 AM
edjunior's Avatar
edjunior
Here you go fireman pat. This is the thread that has the codes and a couple of more links to different sources. The good stuff starts on page 2.
https://www.ford-trucks.com/forums/6...indicator.html
