Transmission compatibility
Old Feb 24, 2009 | 01:29 PM
guywhalen00's Avatar
guywhalen00
I'm building a 2wd 68 F100. I'm putting a 76 460 in it that I built in 2007. It's in a 4x4 right now with a T18 behind it. I want to be able to pull with it and also have driveability. I hate the ZF. I have had trucks with this trans and it drives me nuts it shifts like a damn semi and thats what I deal with all day being a diesel mechanic. I love the NV4500 but I'm not sure if I want to contaminate my Ford with a Chev or Dodge trans. So ultimately my question is about the T-5 and T-56. Will they handle my power, will they pull, and is it as easy as a crossmember and bellhousing swaps? Also for curiosities sake can I put a bellhousing on an NV4500 that will hook it up with my 460?
Old Feb 24, 2009 | 03:35 PM
displacement4me's Avatar
displacement4me
For my 460 I looked at the T-56 initially as well. After some talking with a local parts guy about what I expected for my truck, he said it wouldn't be the best choice for a heavier truck. I ended up getting the Tremec TKO-600, 5spd with .64 ratio fifth gear, and capable of 600 ft/lbs.
Old Feb 25, 2009 | 05:06 AM
OrFordGuy's Avatar
OrFordGuy
tranny ???
the NV4500 mates up nicely using a Norvack or Advance Adapters bellhousing kit. We put one in a 79 Bronco, 38"s lockers, 466ci with a 203/205 case and it works beautifully. Keep it sealed up and well lubed your all set.
DirtyLarry
General Automotive Discussion
Jul 11, 2015 06:29 PM
264WSM
Aug 5, 2014 10:21 AM
mj_355
Jan 7, 2014 07:44 PM
muscletruck7379
Sep 22, 2009 11:42 PM
biz4two
Jul 7, 2004 10:08 PM
