Sponsored by: Auxito
2000 F150 Engine Troubles - No Codes?
Old Feb 24, 2009 | 01:00 PM
Bama-Dawg's Avatar
Bama-Dawg
Requesting any advice or ideas anyone may have. My 2000 F150 has started sputtering and skipping. It started doing it only when going uphill when the motor was strained and would not do it just running along, but now it is starting to do it more and you can feel it missing when you are sitting idle at red light. I had a previous EGR problem, but cleaned ports, etc.. The check engine light went away when I cleaned the EGR ports, and has not come back on. There are no dash lights lit up now. Engine is a 4.6V8 with 170k miles on it. Any suggestions would be appreciated.
Old Feb 24, 2009 | 02:01 PM
KingRanchMan02's Avatar
KingRanchMan02
When was the last time that the spark plugs and wires were changed? Good luck!
Old Feb 25, 2009 | 12:58 PM
Bama-Dawg's Avatar
Bama-Dawg
Changed them at about 115k. Truck has around 180k miles on it now. It does act just like it did once before when it had a misfire on the #8 position, but the dash light came on when it occurrred before. If I change the plugs, should I change the COP's also?
Old Feb 25, 2009 | 01:10 PM
KingRanchMan02
At the very least, use Motorcraft plugs and change all of the COP spark plug boots. If you still have trouble after that, then go for the COPs. Good luck!
Old Feb 25, 2009 | 01:29 PM
Bama-Dawg's Avatar
Bama-Dawg
Thanks for the advice. Will give it a try.
p.j.
1997 - 2003 F150
Nov 24, 2013 02:16 PM
Bronc1
1997 - 2003 F150
Nov 16, 2009 09:11 PM
paulcalif
1997 - 2003 F150
May 5, 2008 01:07 PM
brandon0011
1997 - 2003 F150
Feb 25, 2007 11:13 PM
RGrimes
1997 - 2003 F150
Feb 7, 2006 12:36 PM
