1989 Clutch question
Old Feb 23, 2009 | 06:31 PM
udder's Avatar
udder
I have a 1989 F 250 with 300 six cylinder and M5R2 transmission. I know I need to work on the clutch because I can smell it when towing hard. The fluid level is correct. My question is...does this have a 10 or 11 inch clutch?
It does have the internal slave cylinder.
All help is appreciated.
Old Feb 23, 2009 | 08:40 PM
Beastly's Avatar
Beastly
According to rockauto, if your GVWR is over 8500lbs then you should have an 11" clutch. Under, 10".
I can't offer anymore help than that, as I don't have a 6 cyl. Anyone who knows for sure is likely to chime in soon.
Old Feb 24, 2009 | 07:19 AM
udder's Avatar
udder
You are correct with the answer. I have learned that both sizes will fit. The local parts dealer has agreed to have one of each size on hand this weekend just in case.
Thanks for the help
