Tank float assembly
Old Feb 23, 2009 | 10:45 AM
edub32's Avatar
edub32
Tank float assembly
can anyone tell me or preferably show me how the tank float assembly hooks back on. Mine came off and i'm not sure where it goes back on. Is it through a metal hole? or under a plastic clip? HELPPPPP
Old Feb 23, 2009 | 11:14 AM
brian42's Avatar
brian42
Veteran: Navy
If you scroll down past the procedure there are some pictures that have the float unit in it. They aren't the greatest (since it's for the in-tank mod) but hopefully it can give you an idea of how it is attached.
http://www.itpdiesel.com/other/FuelS...Kit-Manual.pdf
I hope this helps. Good luck.
Old Feb 23, 2009 | 11:19 AM
mueckster's Avatar
mueckster
Did the rod come off the rheostat part of the sender? See figure 10 from Brian's link.
