1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
4x4 Situation when going on snow...
Old 02-22-2009, 05:14 PM
dannielchackas's Avatar
dannielchackas
dannielchackas is offline
All right, my GEM got wet and everything it's working fine again, I discovered a leak in the windshield. So my recently installed xfer case motor seems to be working fine again, it doesnt behave weird anymore, it does switch HI to LOW and backwards now, but I discovered that my 4x4 flashes only on 4AWD so I think what that might be, the sensors, I will deal with that later BUT here the big question,
ever since I ran over blackice and hitting the frontleft tire bending the the rim, I switch to 4hi or 4low on dry pavement it makes a clunk noise like when the front wheel are turning if i go faster it does it more and more, if I disable the 4x4 by removing the fuse 104, it doesn't make that noise at all, but what it's really weird is THAT WHEN I GO 4X4 HI OR LOW ON SNOW IT WORKS PERFECTLY IT DOESNT MAKE ANY NOISES whatsoever an soon as drive over dry pavement it start making that noise.
Any ideas?
I checked the front hub???, seems perfect, maybe CV AXLE? I dont think the front differential is the problem since everythin inside it's always running and turning.
Anyideas?
Old 02-22-2009, 08:22 PM
cbradford's Avatar
cbradford
cbradford is offline
Sounds like a CV joint problem.
Old 02-23-2009, 05:42 PM
ExpySport's Avatar
ExpySport
ExpySport is offline
I'd second the CV joint. If you hit hard enough to bend your rim, you may have done some hidden damage, too.
skidooracer_22
1997 - 2003 F150
01-08-2014 06:43 PM
rgd420
01-10-2011 09:33 AM
dannielchackas
12-17-2008 01:43 PM
xfactor_279
19
02-04-2008 08:18 PM
Gordon Wardlaw
Bronco II
10-06-2003 11:08 AM
Quick Reply: 4x4 Situation when going on snow...
