Gpr led ?
Old Feb 22, 2009 | 04:14 PM
61 uni's Avatar
61 uni
Gpr led ?
I got the LED last night and I want to use a blade fuse in it. What fuse do I need?
Old Feb 22, 2009 | 04:19 PM
ron's power stroke's Avatar
ron's power stroke
.5 or 1 amp at most
Old Feb 22, 2009 | 06:07 PM
nlemerise's Avatar
nlemerise
I'd go with a much smaller fuse than a 0.5 or 1 amp fuse. Those LED's generally draw a maximum amperage of 15mA. A 0.5 amp is 500mA and that LED will be fried long before that fuse goes pop. The 0.5 amp will save the wiring, but not the LED.
Old Feb 23, 2009 | 09:41 AM
superduty4x4's Avatar
superduty4x4
Neal- that's the goal, protect the wiring. The LED's most of us are using have a built-in resistor so we won't be blowing them to bits by putting 12v of power to them.
I've been told anything less than 5amps is fine. Just be sure to put the fuse as close to the GPR as you can, and keep the wire tied up as best as possible. The goal here is to not have a long piece of wire with voltage running through it should things go haywire.
Old Feb 23, 2009 | 10:04 AM
mueckster's Avatar
mueckster
I have my fuse holder right near the relay post, so that the entire length of the wire is protected. I have a 1 amp fuse. I used 14 ga speaker wire to run inside the truck. It was easy because the wiring was already there from my old switched 10k mod. I put the LED i n the dash where the switch used to be.
