Timing chain for Expedition
Old Feb 22, 2009 | 03:52 PM
molin3's Avatar
molin3
I am trying to install a timing chain on a 200 Ford Expedition with a 4.6 Windsor DOCH. I've read several manuals and none of them speak straight talk or even show an exact "blow up view" of these timing marks. The keyway and the dimple are in two seperate locations on each sprocket. Which is the mark. what and where do these timing marks need to be in order to put this chain back on. Can someone please give it to me straight...
Old Feb 22, 2009 | 04:05 PM
73f100shortbed's Avatar
73f100shortbed
Do you have access to alldata? They have good instructions. Make sure you have the tools to hold the camshafts in place as well.
Old Feb 22, 2009 | 06:37 PM
pdqford's Avatar
pdqford
Just an FYI, an Expy 4.6 Windsor is a SOHC engine (i.e, a single overhead cam per head). The Navigator Intech is a DOHC engine (i.e, two overhead cams per head).
In other words, a SOHC V-8 engine will have a total of two cams, while a DOHC V-8 engine will have a total of four cams.
Old Feb 22, 2009 | 09:17 PM
alloro's Avatar
alloro
The copper colored links on the chain should be at the marks on the sprockets as noted by the "A" in the circles.
MoJensen87
Aug 6, 2014 02:02 PM
Chadloe99
1978 - 1996 Big Bronco
Jul 1, 2013 10:21 AM
riverguideguy
May 10, 2013 08:28 PM
Gembone
Modular V8 (4.6L, 5.4L)
Jan 8, 2013 10:40 AM
Nevada Dan
20
Jul 31, 2011 10:59 PM
