Aftermarket Products
Sponsored by: Worksport
diff in MSD ingnition
Old Mar 7, 2001 | 06:01 PM
78bronco's Avatar
78bronco
what's the diff between the 5A and 6A? advantages, which is better, increases in power /gas mileage
Old Mar 8, 2001 | 06:36 AM
stairbuilder's Avatar
stairbuilder
The MSD 5 is a lower output type box for daily driver use with no increase in fuel load, I.E. Cams, manifolds, carbs, etc.
The MSD 6 is designed for as said above, an increase in fuel load, and or compression with a greater power output to overcome larger static loads. Keep in mind you'll need a good coil to make it all come together. In switching to a Capacitive Discharge (CD) ignition, the coil will get a full saturation (unlike conventional ignition) and will overheat more rapidly. Spare no money on the coil or it'll leave you stuck one day.
Hope that helps.
Chris
Old Mar 20, 2001 | 08:57 AM
ripf350's Avatar
ripf350
