years models without 390 option
Old Feb 21, 2009 | 11:35 PM
roger dowty's Avatar
roger dowty
i thought i had this down and searched without success so this is to hopefully pound it into my head and have a title that will be found in a search.
what models and years were not able to sport the 390 from the factory.
thanks
Old Feb 22, 2009 | 01:40 AM
460's Avatar
460
1977, 1978, and 1979 = No 390 or 360.
Old Feb 22, 2009 | 09:54 AM
akparker1's Avatar
akparker1
in 77 they went to the 351m/400
Old Feb 22, 2009 | 12:14 PM
Dr. Dirt's Avatar
Dr. Dirt
also there was no 4 BBL 390 in 1973.
Old Feb 22, 2009 | 05:56 PM
roger dowty
so there is no model other then the 77.5 and up that did not come with a 390 as an option? ...like crew cabs etc?
i'm not including 360's as 390's.
doesn't sound right
Old Feb 22, 2009 | 06:52 PM
76f350spercamprspeal's Avatar
'76 was the last year for the FE,or so I have been told.
Old Feb 22, 2009 | 07:02 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1968/76 F100/350
The engine code is the 4th digit of the VIN.
H = 390 2V
M = 390 4V (1974/76 only)
Y = 360 2V
4WD: The 360 2V only was the only V8 installed 1968/76.
No 360/390's in F100/350's before 1968 or after 1976.
Old Feb 25, 2009 | 07:33 AM
OrFordGuy's Avatar
OrFordGuy
correct the 77 1/2 model year was the last for the FE motor in any vehical really. Ford however stuffed a few in the late 77s to clear inventory on the FE.
Old Feb 25, 2009 | 08:46 AM
NumberDummy
Originally Posted by OrFordGuy
correct the 77 1/2 model year was the last for the FE motor in any vehical really. Ford however stuffed a few in the late 77s to clear inventory on the FE. Sorry, incorrect.
I don't know where you're getting your info from, but what you say about FE engines is in-correct.
1968 was the first year the 360 and 390 were offered in F100/350's.
1976 was the last year the 360 and 390 were installed in F100/350's.
1965/67: The only V8 available in F100/350's was the 352 2V.
1977/79 F100/350 V8's: 302 2V (F100/150 only), 351M 2V, 400 2V and 460 4V.
V8 4WD's: 1965/67: 352 2V / 1968/76: 360 2V / 1977/79: 351M/400.
There is no such Ford thing as a 1977.5. Some people refer to 1977.5 inre to the last High Boys, but Ford never did.
The last 1977 F250 4WD (High Boy) was assembled before serial number Y20,001.
All the 1977 V8 4WD's...High Boys or not, came with either 351M's or 400's.
Old Feb 25, 2009 | 09:24 AM
OrangeJuice's Avatar
OrangeJuice
OK, so this thread comes at a good time as I have a question. Will a 390 fit in a 1977 F-150 2WD with a C-6 originally equipped with a 351M? Are the motor mount brackets to the frame in the same location so the motor mounts on block line-up or do the brackets have to be changed? Is it a drop and go?
Thank You
Old Feb 25, 2009 | 12:47 PM
Jermafenser's Avatar
Jermafenser
Amended:
460 4V was only available on F100 in 1974, and 1977-79 F150 or heavier.
Old Feb 25, 2009 | 12:59 PM
NumberDummy
Originally Posted by Jermafenser
Amended:
That's not what I recall, and the parts catalog doesn't agree with you.
Look up 6038's or 6068's, it sez right there 1973/79 F100/350.
btw: In CA in 1979, you could not get a 460 in anything but an F250/350 because of the emission requirements BS.
I bought a new Lariat Stupor Cab, had to settle for the 400.
Old Feb 25, 2009 | 01:38 PM
Jermafenser
Just saw them.
I have a 1978 F-series buying guide from back then, and it sez 460 4V was only available in F150 or heavier except in CA as you previously stated. It also sez you aren't able to get a 300 or 302 in CA in Supercabs, only regular cabs.
I had a factory-installed 460 in a '79 F150 2wd. Didn't make much difference in power from a 400 due to smog requirements.
Old Feb 25, 2009 | 01:47 PM
NumberDummy
Just saw them.
The reason I wanted a 460 was...the 351M and 400 engines were in-famous for cracking cylinder heads.
Both were gutless smogged up terds and neither one had enough get up and go to pull a sick trollop off a porcelain device!
Old Feb 25, 2009 | 04:24 PM
Dr. Dirt's Avatar
Dr. Dirt
thank God that I don't have to put up with smog testing in the good ol' state of Texas with my 79. IIRC, 75 and up has to smog test in Cali, right?
