Glow plug issue
Old Feb 21, 2009 | 07:53 PM
copperdog's Avatar
copperdog
Glow plug issue
Gentlemen;
The vehicle is a 1992 Ford with 7.3 IDI engine
The issue is the second glow plug back on the left side is having repeat failures.
The first time it just failed open.
The second time i tested it, open and when i went to remove it, it was difficult to remove from the hole. When i finally got it out, the bottom was expanded, the very bottom of the part that gets hot. I thought maybe a defective new glow plug?
I have a bore light that I can see inside the bore and no obstructions or anything contacting anything.
I then screwed another defective one in and torqued to 12 ft pounds, then removed it, looked good.
I then installed a new glow plug, torqued to 12 ft pounds, cycled the key and tested the glow plug, failed new glow plug, one key cycle. I tried to remove it and the same problem, swelled up at the verry bottom about 1/4" up from the tip.
This all started after installling a set of reman cylinder heads. The controler has also recently been replaced.
Anybody have any ideas?
Thanks
Old Feb 21, 2009 | 08:26 PM
PLC7.3's Avatar
PLC7.3
Only install BERU Motorcraft glow plugs ZD9.... remove any other brand cautiously....
Old Feb 22, 2009 | 08:16 AM
copperdog's Avatar
copperdog
Pictures
I have some pictures, not sure how to post them?
Old Feb 22, 2009 | 08:48 PM
Dave Sponaugle's Avatar
Dave Sponaugle
copperdog,
Welcome to FTE and the IDI diesel forum.
Start by setting up a gallery, third from left in the grey bar below the FTE header.
The select manage/create from the drop down box.
