Find a standard torque chart for that sized bolt...... that will be it. Retightening should not be necessary since it is a silicone sealant gasket........ unless someone put a composite gasket in there.
i took the oil pan off cleaned of the silicone sealent off and am redoing the process i was just trying to figure out if someone know the exact specs ... but if no one knows the anwser ill prob just tighten um all real good.
