Its back #$@ !!!
Old Feb 21, 2009 | 04:50 PM
uno's Avatar
uno
Its back #$@ !!!
P1506.... after new IAC and TPS, can not locate a vac leak. IDLE is back to 1100 rpm on my 2001 5.4 expedition, HELP ! did anyone else have same issue/same truck ?
Old Feb 21, 2009 | 07:33 PM
uno's Avatar
uno
where is the pcv on the driver's side just about half way down the valve covers right ?
Old Feb 21, 2009 | 09:50 PM
madsonp's Avatar
madsonp
Passinger side.
Old Feb 22, 2009 | 07:00 AM
shorebird's Avatar
shorebird
Take a can of WD-40 and while the engine is running work your way slowly around the engine spraying the vacuum system. Listen for a change in the idle. When you hear the change you have found the leak.
Old Feb 22, 2009 | 08:00 PM
uno's Avatar
uno
Thumbs up solved
after a new TPS and IAC........ PCV for a whopping $3 base idle back to 600-650.problem solved thank guys.
