Misfire on Cylinder 6? It's not plugs, COP or Injector...
Old 05-13-2009, 01:35 PM
KingRanchMan02's Avatar
KingRanchMan02
KingRanchMan02 is offline
Originally Posted by rsylvstr
are aftermarket any good? (I guess that's like asking what oil is the best)
I bought a set of these COPS and plan to install them in the near future. I expect them to cure my random high load misfire problem. By the way, this company is an FTE sponsor and they provide a discount to FTE users.
http://www.performancedistributors.com/soscoils.htm
Old 05-13-2009, 02:00 PM
skuenkel's Avatar
skuenkel
skuenkel is offline
John, thanks for the link to the parts. That helps. Will see how it goes.. thanks again.
Old 05-13-2009, 03:13 PM
Bunggo's Avatar
Bunggo
Bunggo is offline
Originally Posted by skuenkel
I have the similar problem on a 2001 F-150, 4.6, 2whl, 110k miles. Was getting very bad jerking when accelerating, especially at low RPM (like after it shifts to next gear). Last week I finally took it to the dealer. They replaced COP and plug on cylinder 1, $381 dollars later and it ran fine for 4 days. Then a few days ago it started to jerk every once in a while when accelerating, but then today I could barely make it up a hill with so much jerking. I took it back to the dealer and they told me it was now cylinder 6 coil gone bad and want $235 to replace AND mentioned there was browning in that cylinder signifying some water there????
I asked why it didn't show up on diags last week but no solid answer worth mentioning here... my thought is to replace the plug and coil myself for $63 but after reading some of these posts makes me wonder if we are guessing and if cyl 6 is really the issue. I searched ebay for the coil set but nothing there but one used set....
any suggestions would be appreciated.. thanks
Just because the OBD says P0306 doesn't mean the issue is with 6. I believe my issue was with 7, and there was enough noise for 6 to throw the code (which I have read about happening in other's posts). Just keep looking on ebay.
These would probably work for you. I did a search for DG508 and found them:
NEW IGNITION COILS 97-06 FORD F150 F-150 V8 DG508 (8):eBay Motors (item 120419418208 end time Jun-10-09 21:18:41 PDT)
Bunggo
Old 05-13-2009, 03:30 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
there are some days, after reading so many posts, that i just feel like buying a set to avoid future problems, but i'm not one to waste money.
Anyone think there's a reason to change when there isn't a problem????
"stronger spark"
do they get weaker or just go?
Old 05-13-2009, 03:39 PM
Bunggo's Avatar
Bunggo
Bunggo is offline
"stronger spark"
Well, I don't know for sure, but I believe they just go. It doesn't put you out though. I drove on mine for a few weeks. It's still not good though because it drives your gas mileage down. I could be wrong, but I don't think new ones give you a better spark or anything of the sort. They should last forever and do in most cases. So, I wouldn't buy them just to have them.
Old 05-13-2009, 04:38 PM
KingRanchMan02
What happens as the COPs age, is that the coil windings short out. What causes this is the spark plug gap can get substantially more than the specified gap as the plugs wear. The increased gap causes the coil to overheat which results in coil output being too low to fire the plug. The overheating of the coil causes windings of the coil to short reducing the overall output of the coil. With less output and high engine loads, the coil begins to no longer produce enough output to fire the plug. This is felt by the owner as bucking in the 45 - 55 mph range.
Old 05-13-2009, 04:50 PM
Bunggo's Avatar
Bunggo
Bunggo is offline
(I mean this as a compliment) Are you the Alton Brown of mechanics?
Certainly a much better answer than my own!
Old 05-13-2009, 05:01 PM
rsylvstr's Avatar
rsylvstr
rsylvstr is offline
KingRanchMan02
thank you. so is what they say on their site pretty much bunk or can the increase voltage help at 105k miles? and would this only help if i increased the gap? I'm all about saving money and leaving it alone if it's not going to help. thanks for the advice and patience.
Rob
The SOS Coils are designed with increased windings to boost spark output up to
40,000 volts! That is a 60% increase in spark energy over the 25,000 volts produced by the stock
coils. The higher voltage along with increased spark duration will allow plug gaps to be opened up
to .065". This larger gap exposes a hotter spark in the combustion chamber for an increased burn
of the fuel mixture, resulting in more horsepower and better fuel economy. Additional benefits
include quicker starting, smoother idle and greater throttle response.
Old 05-14-2009, 09:27 PM
KingRanchMan02
KingRanchMan02
Rob
Having an electronic/electrical background, the increased output is exactly why I purchased a set for myself.
Old 05-14-2009, 09:29 PM
KingRanchMan02
Thanks!
Old 03-25-2010, 09:46 PM
mrmauer's Avatar
mrmauer
mrmauer is offline
This all sounds familiar. Flashing CEL. Mechanic replaces COP, says all is OK. Drive 2 blocks, light back flashing. Go back, they change injector. It still runs rough. They check compression and it is at 70 PSI and they are looking for 160. They give up and say go to dealer. Any thoughts ? I posted the final story, which I hope is not a new engine for an 03 with 110,000 miles.
Old 03-25-2010, 10:06 PM
Bunggo's Avatar
Bunggo
Bunggo is offline
How many COP's did they replace? I was getting misfire on cylinder 6 but the problem was a different COP. What happens is that sometimes there ends up being enough noise on the line that the DTC codes are incorrect, so the problem probably isn't the COP that was replaced. My cylinder 6 COP was probably OK, a different one was causing the problem. I replaced all of them and solved my problem. I bought 8 of them on ebay for $80 bucks or so. Also replaced all my spark plugs.
You probably didn't need the new injector.
  #28
Old 03-25-2010, 10:55 PM
mrmauer's Avatar
mrmauer
mrmauer is offline
The mis-fire was on #1. They just replaced that one COP. I was reading that elsewhere about the code lying about where the mis-fire occured. I thought when the code was read the 2nd time it showed an injector problem. But, you are probably right. I should have had them do all the COPs/plugs/wires. At 110,000 miles they are due. It is sitting at dealer now, until Monday. I'm worried, more about the low compression reading of 70, which does not seem related to COP/plugs/wires. More like piston rings or cyl head.
Montana_Rig
2004 - 2008 F150
31
09-30-2021 08:54 PM
Steve369
1997-2006 Expedition & Navigator
46
07-25-2018 01:27 PM
KeyKeeper
Modular V8 (4.6L, 5.4L)
17
06-21-2017 09:24 AM
BiggyE
05-12-2016 02:37 PM
04150
2004 - 2008 F150
02-03-2016 07:24 PM
Quick Reply: Misfire on Cylinder 6? It's not plugs, COP or Injector...
