programmers
Old Feb 21, 2009 | 12:43 PM
ropeslinger's Avatar
ropeslinger
programmers
i have a 2004 f-350 king ranch 4x4 with a 6.0 liter powerstroke. i am wanting to purchace a programmer to try to up my fuel mileage. most of my driving is empty, but sometimes pulling a two horse trailer or gooseneck utility trailer. either case, nothing real heavy. any suggestions? brands? i dont want to spend 3 or 4 hundred without results!
Old Feb 21, 2009 | 12:54 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
Welcome to FTE......get SCT tuner and download some Spartan files. they free and you enjoy it. but first do gauges boost exhaust probe and trans temp to monitor whats up with the truck, than put a 4" exhaust system of your choice you can just do CAT delete. that alone will give you MPG gain....this will uncork your truck..
and make sure all the oil and fuel filters including your air filters are up to par...
stick around and ask any questions you you can find an answer to.
Old Feb 21, 2009 | 02:06 PM
hangon2me's Avatar
hangon2me
You forgot to suggest, an EGR blocker plate to keep your EGR cooler from overheating.
Very important to protect your engine from sucking in Anti-freeze.
I am running Aggressive Street Economy as a daily driver, I suggest not to TOW with it.
Welcome and visit often, most of your questions have already been answered if you
search this Site.
Old Feb 21, 2009 | 02:10 PM
88stang1's Avatar
88stang1
I have a superchip Cortex and love it and it comes with a 2 year powertrain warranty I agree with Pete about the exaust and gauges and good maintenance they are a must if you are going to unleash the fury of your 6.0L PSD
Old Feb 21, 2009 | 02:23 PM
88stang1's Avatar
88stang1
With a SCT tuner it will limit the egr valve it will not shut it down completly but it will cut it down substantially
Old Feb 21, 2009 | 03:49 PM
hangon2me's Avatar
hangon2me
Originally Posted by 88stang1
With a SCT tuner it will limit the egr valve it will not shut it down completely but it will cut it down substantially
Yes this is correct it cuts down the cycle duty, I blocked my EGR Cooler on the intake at the Turbo up-pipe (leave the EGR valve plugged in). I did not want to take any chances of bursting my EGR cooler from the extremely hot exhaust Temps. from the programmer. If the EGR valve is not opening the extremely hot exhaust will still enter the EGR cooler and cause hot flashing (causing the solder to melt and fail). Block or full delite is my #1 suggestion, Gauge(s), full Turbo back 4" exhaust and then let's talk about a programmer.
Old Feb 21, 2009 | 04:35 PM
04F-250mark's Avatar
04F-250mark
Likewise ,WELCOME ABOARD! You will find this place full of very knowledgable people and advice.
Old May 31, 2009 | 08:34 AM
Unc1eJesse's Avatar
Unc1eJesse
Does anyone here any experiences with the Gryphon programmer from power hungry performance.
Old May 14, 2010 | 02:45 PM
Briarglenn's Avatar
Briarglenn
Hi, I'm new to the FTE site, and recently had my Edge Advantage chip go bad on my 2004 350 SD. I'm considering purchasing a Superchip Cortex as I hope to upgrade to a newer Ford pu in the next couple of years. Any info you can give me at jrcrcampng@yahoo.com would be appreciated.
Old May 14, 2010 | 04:32 PM
beemr's Avatar
beemr
What happens if you tow with an aggressive street tune?
By towing, I mean short trips around town towing a utility trailer or such?
Is the only concern when towing with a high power tune the EGT's?
Old May 14, 2010 | 04:55 PM
cheezit's Avatar
cheezit
with enugh load and the wrong tune you will puke out of the degas bottle.
Old May 14, 2010 | 05:49 PM
69cj's Avatar
69cj
I also might add that a tuner is not a mileage adder. Some people get slight increases but that has been the exception to the rule. programmers are for power.
Old May 14, 2010 | 05:59 PM
texans's Avatar
texans
Like 69cj said never install a programmer with a mpg gain being the reason. You will only end up with dissapointment. When you don't see any gain. If there is any it will be very slight. A programmer is made to produce more power. If you see any gain then just consider that a plus. If you do get one stick with one that offers custome tunes (sct or Spartan) as this will give you the best chance of seeing a mpg gain. Plus they are much much better for your truck.
