Built cobra jet 460 cost value
Wondering if anyone could give me a price on what a fully built 460 would be worth with the following components:
1976 460 block
428 cobra jet heads
blue fender intake manifold
750 holley
double roller chain
shot peened rods
msd ignition
canton oil pan
9.5 to 1 compression
scj spec came
meling high volume pump
balanced, blueprinted and crossdrilled motorsports crank
ss headers
jacobs electronics
motor was built to run on any type gas. horsepower is said to be about 600??? not sure on that but in compression is raised maybe so. What do u think is a good price to pay for this engine????
Thanks.
1976 460 block
428 cobra jet heads
750 holley
double roller chain
shot peened rods
msd ignition
canton oil pan
scj spec came
ss headers
jacobs electronics
Thanks.
This is bogus for several reasons. First 428CJ heads are from a different engine family and will not physically fit. Second a 750 carb is smaller than came on the 429CJs. Third, the compression is lower than stock CJs ran. So fully built is also wrong as fully built motors don't run on pump gas. Lastly, what's a came?
they are nothing but stock passenger car heads without the proper casting numbers, a 750 is plenty on a mild street engine but not enough on a "built" 460.
Also on PI heads you do have to specify if they are 429 or 460 PI heads (they are different) and PI heads are NOT CJ heads although they are good.
Also WHAT motorsport crank? the only "motorsport" cranks for the 385series engines are the 4.3" stroker cranks that use the larger rod journals then the typical stroker cranks. and if it's got a stroker crank in it, then it's not a 460.
If this is an engine you looking at buying I would say run, cause the seller is blowing smoke up somewhere and doesn't have a clue.
As greenhighboy put it, maybe these are the ultra rare D3 cobra jet or the E7TE PI heads and probably has the D7TE 4 bolt main truck block too.
Basically if the guy doesn't know enough to list stuff honestly then I wouldn't trust him on any of it.
heads are 429 pi heads? are they any good? expensive or rare?? what year did ford produce pi heads and what for? whats the difference between pi and cobra jet 429 heads. motor make over 500 hp and 600 lb/trq on pump gas at 9 to 1?? also intake is a blue thunder?? what do u guys think???????? will have castings #'s tomorrow. thanks.
do you KNOW they are PI heads? Or were you just told they were? What are the casting numbers, cause without those they it's all advertising, everyone has CJ and PI heads until actual push come to shove and show the numbers.
as to value of true PI heads, more then passenger car heads, less then true CJ heads. power potential falls in the same area.
here is link to web site listing f100 sale
1969 f100 PRERUNNER 460 - DezertRangers.com
what do u think value of motor is?? $9500 invested in motor alone?
thanks
rob
thanks
rob
Like monsterbaby said, it's all advertizing until he produces the head numbers. I wish I had a buck for every 360 became a 390 or a 390 that became a GT or a PI on sale day or better yet a390 that became a 428CJ. Anyone can write whatever they want in their ad. It does not make it so.
I thought Ford 9" rears are 28 Spline? Can you fit 31 Spline?
$15000, run as fast away from that as you can.
If I had a Buck for every 78-79 F100 -F350 that was advertised as a Hi-Boy, and a Buck for every 73-79 F-150 4x4 that was advertised as a Stock 460. I could retire.
