Lost dash lights, power!
Old Feb 21, 2009 | 09:00 AM
tommyl's Avatar
tommyl
My freind has a 2001 F350 Autotrans. Last night he let the truck idle all night. today when he left, the truck does not shift into O/D, hit o/d button then gauge lights went out. There are no lights flashing! No code reader with him. Sitting along interstate!! Some quick help please, Thanks..
Old Feb 21, 2009 | 09:08 AM
Kwikkordead's Avatar
Kwikkordead
I'll bet the alternator failed and the batteries ran dead.
Old Feb 21, 2009 | 09:09 AM
Kwikkordead
Where is he at anyway?
Old Feb 21, 2009 | 09:15 AM
megawatt00's Avatar
megawatt00
I agree Dan. Maybe there is someone close by that may be able to help.
Old Feb 21, 2009 | 09:21 AM
tommyl's Avatar
tommyl
He is sitting at mm212 on I-80, near Austintown. I had him shut truck off and it restarted, pulled vss sensor to clean. Is there a sensor on trans. that would have some affects?
Old Feb 21, 2009 | 09:23 AM
tommyl's Avatar
tommyl
Austintown, Ohio
Old Feb 21, 2009 | 10:20 AM
tommyl's Avatar
tommyl
Just pulled codes at Autozone and nothing shows. Truck is running and shifting, but not good. Lacks power and there is no dash gauges working. Fuses seem to be ok so far.
Old Feb 21, 2009 | 10:33 AM
megawatt00's Avatar
megawatt00
The code readers at Autozone won't read the codes on a PSD.
Old Feb 21, 2009 | 12:07 PM
tommyl's Avatar
tommyl
Fuse # 19 was bad!!
Old Feb 21, 2009 | 12:21 PM
megawatt00's Avatar
megawatt00
That would do it
Fuse #19 10A
Auxiliary Powertrain Control Module
(APCM) (Diesel only), Instrument Cluster,
GEM Module, Overdrive Cancel Switch,
Idle Validation Switch (Diesel only),
Overhead Console, Diesel PCM via Clutch
Old Feb 22, 2009 | 09:37 AM
Kwikkordead
LOL.
This good outcome should really be a lesson to us readers.
Check the basics first like battery condition and whether all the fuses are good!
