hi Im looking for some wiring from a 1975 to 1977 ford pickup. need the ac circiut wiring with the wires for accessory safety relay also to the coldbox any help would be great. need just those year trucks only thanks joe from n.j.
This is probably the 10th time you've posted this; and it hasn't turned up. You're either going to have to find it in a junkyard, or make your own based on a factory wiring diagram. Autozone's website has some decent wiring diagrams.
Is either one of these what you are looking for?
D5TZ19A885A .. A/C Wiring Harness / From Main Wiring Harness to Blower Motor Resistor / Use with factory installed Integral A/C / Obsolete
Fits: 1975/77 F100/350.
----------------------- D5TZ19A885B .. A/C Wiring Harness / From Blower Motor Resistor to Ambient temperature Switch / Use with factory installed Integral A/C / Obsolete
Fits: 1975/76 F100/350.
No Ford Dealer or obsolete parts vendor has any.
----------------------------------------------- What do you mean by "thecoldbox," the A/C Heater plenum chamber?
With factory installed Integral A/C, the main wiring harness is different than without.
yes the ac heater plenim someone told me you could unplug the heat only harness an plug in the ac harness an continue down the line from there to the blower motor.
