How Much TIMING
Old Feb 19, 2009 | 07:04 PM
1966Tbird's Avatar
1966Tbird
How Much TIMING
how much timing are you guys running on your 5.0 pickups initial and total and when it's all in by right now i have mine running 8*initial and i think 36* all in but i forget it's set to be all in at 2800 i was thinking bumping up the initial to 10-12* or maybe higher depending on what you guys think
motor specs:
Adv. Duration: 300 intake/ 310 exhaust
Duration @ .050: 224 intake and 234 exhaust
Valve lift: .496 intake and .520 exhaust
Lobe C/L: 112
Flowtech Long Tube Headers
2.5in exhaust turbo mufflers
Ported E7 heads
RPM Air Gap Intake manifold
Holley 570 Street avanger w/ jet extentions
Pro Billet HEI Dissy with a Mallory Coil
Ford Motorsport Plug Wires
NOS powershot system 125shot (i'm gona pull out about 5* of timing before i spray it)
3500 stall converter AOD trans
3.73 gears detroit lockers all around 33in all terrains
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig --><!-- sig -->
Old Feb 20, 2009 | 09:25 PM
393STROKER's Avatar
393STROKER
When I had the 5.0 in my `90 truck I had it at 12 deg. most of the time.With the new 393 I have it up to 17 but I`m putting octane booster in w/premium Shell gas and it seems to run crisper.I just kept advancing it until I found the sweet spot
Old Feb 20, 2009 | 10:10 PM
1966Tbird's Avatar
1966Tbird
yeah i think i'm gona advance it a little more i run 96 octane
Old Feb 21, 2009 | 02:59 PM
fordeverpower's Avatar
fordeverpower
first octane boosters is a scam, better off buying premium. Now your old school camshaft bleeds off more compression than a stock one. It results a lower dynamic compression ratio and thats whats important for fuel requirements, not the static compression. Having your timing all in by 2800 may need some more octane.
I also would increase the timing, do you use any vac advance?
Old Feb 21, 2009 | 04:26 PM
1966Tbird's Avatar
1966Tbird
we actually buy an 96 octane mix from VP race fuels in 10,000 gallon quanities for everything on the farm
and no i don't use vacuum advance i run just mechanical advance
Old Feb 21, 2009 | 04:57 PM
fordeverpower
i would try to get up around 16-20 inital if i was you, as long as it restarts warm.
Old Feb 21, 2009 | 05:10 PM
1966Tbird's Avatar
1966Tbird
yeah i tried 12* initial today and it ran great but i need to adjust something because it detonates when i take my foot off the throttle or make the transition from three quarter throttle to half throttle i think maybe my carb is out of adjustment just by a littlebit
and the more timing i give it the worse it gets
Old Feb 21, 2009 | 06:37 PM
fordeverpower
I take it you are running some lighter springs in your dizzy. You may be stuck with 8 degrees since you have it coming in so fast. heavy vehicles don't like the timing so as a lighter car would.
Old Feb 22, 2009 | 03:02 PM
1966Tbird's Avatar
1966Tbird
yeah i'm realizing that with the converter (3500 stall) i have in the truck it isn't a problem at all and has really good power and everything till i get in 3rd with the converter locked up and the secondaries open, when i let off the throttle the secondaries close and i can feel detonation so i'm thinking about putting some heavier springs in it and running all in at 3000 or 3200
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
sddesigns
New Jersey Chapter
Jan 28, 2010 05:46 PM
