how much timing
Old Feb 19, 2009 | 05:05 PM
1966Tbird's Avatar
1966Tbird
how much timing
how much timing are you guys running on your 5.0 pickups initial and total and when it's all in by right now i have mine running 8*initial and i think 36* all in but i forget it's set to be all in at 2800 i was thinking bumping up the initial to 10-12* or maybe higher depending on what you guys think
Old Feb 19, 2009 | 07:06 PM
1966Tbird's Avatar
1966Tbird
motor specs:
Adv. Duration: 300 intake/ 310 exhaust
Duration @ .050: 224 intake and 234 exhaust
Valve lift: .496 intake and .520 exhaust
Lobe C/L: 112
Flowtech Long Tube Headers
2.5in exhaust turbo mufflers
Ported E7 heads
RPM Air Gap Intake manifold
Holley 570 Street avanger w/ jet extentions
Pro Billet HEI Dissy with a Mallory Coil
Ford Motorsport Plug Wires
NOS powershot system 125shot (i'm gona pull out about 5* of timing before i spray it)
3500 stall converter AOD trans
3.73 gears detroit lockers all around 33in all terrains
Old Feb 20, 2009 | 12:37 AM
1966Tbird's Avatar
1966Tbird
anybody know....common you've all had to play with the timing in your trucks
Old Feb 20, 2009 | 03:54 AM
lew52's Avatar
lew52
I run 10 deg base timing..not sure of total timing... Custom chip..Just know what tunner wrote on dyno sheet That the truck likes a 12.8:1 air fuel ratio with an aggessive timing cure 93 octane fuel....We use a MSD timing box so we can retard or advance the timing with the turn of a **** on dash..This is good for nitrous...You can retard the timing before you spray & turn it back when your done so the truck runs good..If you use 93 fuel i would think you could run 12-14 base timing..Sometimes just play with it see if it likes it ..
Old Feb 20, 2009 | 04:50 AM
EPNCSU2006's Avatar
EPNCSU2006
Most people in this forum are running EFI and can only adjust the base timing, which shifts the curve up or down, but the shape of the curve can't be changed unless a custom chip or tuner is used.
Old Feb 20, 2009 | 10:40 AM
1966Tbird's Avatar
1966Tbird
that makes sense thanks for the responses i run 96 fuel in it so i think i'm going to try like 12 or 13* today and see if it's pinging, i would love to get a timing retard **** hah is that politically correct? but i dont have the money to spend on an msd box and the **** and i have an HEI dissy so i'm not even sure how i would wire up the box
Old Feb 23, 2009 | 08:48 PM
Dukernc's Avatar
Dukernc
Hey 1966Tbird,
FYI. I run @ 12 deg with 89 octane on my 90'. Hope this helps..
Old Feb 23, 2009 | 08:57 PM
1966Tbird's Avatar
1966Tbird
thatnks that does help i have been playing with my timing curve all day and almost have it down but just ran into a charging problem and now my alternator isn't charging for some reason, really really pisses me off cause i just replaced the entire charging system
