Brake Question???
Old Feb 19, 2009 | 04:57 PM
PsD007.3's Avatar
PsD007.3
Brake Question???
soo one day i'll leave my house my truck will pull hard to left when braking, next day it wont pull at all, and maybe 2 days later it might pull to the right...why would it be doing this???
Old Feb 19, 2009 | 05:11 PM
megawatt00's Avatar
megawatt00
Possibily your slide pins sticking??
Old Feb 19, 2009 | 05:27 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thats the first thing I thought of too, Jim. Here is how to grease them and take them apart. Welcome to guzzle's Front Caliper Slide Pin Upgrade Web
Old Feb 19, 2009 | 06:34 PM
mybigredford's Avatar
mybigredford
reading guzzles write up, he says not to put too much silicone lubricant in the slide pin hole as it might hydrolock. when i did my pin a while back i noticed that the pin would be quite tight with pressure but then eventually you could hear air release and the pin would go all the way in, is that the right thing to do, try and get all the air out of the pin hole??
Old Feb 19, 2009 | 11:34 PM
PsD007.3's Avatar
PsD007.3
ok idk if it had anything to do with my leveling kit with-out a trac bar drop bracket
