Intermittant no start in park FYI........
For those with an auto transmission and the problem in the title. Looks like you can adjust the gear select indicator. If you take off the fuse panel access door there is a little gear looking thing that can be adjusted by turning. It has a little copper wire that goes to the shift linkage. I adjusted the indicator so that the indicator was in the center of the park position. At first it did not start in park so moved to nuetral and started. Shut the truck down and started in park. Seems like the slop in park is better, I guess only time will tell. I'll try to post if a pic if I can figure out how.
Here a link to a pic in photobucket: Adjusting shift indicator picture by galexander - Photobucket
Looks like all is good with my truck. I can hold down on the shift lever in park and it still starts. If I did this before it would not start. I would either have to hold up on the shifter lever or start it in neutral. It only took me a year to look at it. Lol.. I don't drive it that much. Hopefully, this can help someone else..........
