TLC Time
Shocks need replaced but I'm holding off a little bit 'til I can afford to lift.
lube / oil / filter
transmission service
front & rear axle fluid change
torque converter fluid change
radiator / cooling system flush
rotate & balance
Thanks in advance for the help.
Check air filter, if dirty replace (or clean if K&N).
Check the crankcase breather filter.
Replace fuel filter if it hasn't been done.
Check and replace PCV valve if you know it hasn't been done or its really dirty.
Possibly run some Sea Foam through the engine if you want to mess with it.
Check to make sure all your coolant hoses are in good shape before radiator flush.
Check vacuum lines and such for cracks.
You could also check for computer codes just in case.
Just some typical things there that are easy to forget also.
Put a socket on crank and see how much timing chain slack.
Check air charge and coolant temp sensors by putting in oven and checking resistance compared to the charts even is not throwing codes.
Fan clutch.
Inspect coil output terminal for signs of arcing.
Good cap and rotor, wires, copper plugs.
Red-head steering box if it has slack.
