Perhaps the dumbest question?
Old Feb 18, 2009 | 01:22 PM
Quick444's Avatar
Quick444
I hate to be annoying but I just want all my ducks lined up in a row before I start driving long distance to look at trucks.
How can I tell the difference between the 7.3 and the 6.0 if there isn't any cosmetic shroud to notify me of what I am looking at.
I ask because I am finding some deals thats seem too good to be true and I just ponder if the dealership is wrong in listing the 7.3.
Sorry but thanks in advance.
Old Feb 18, 2009 | 01:24 PM
superduty4x4's Avatar
superduty4x4
The motor looks totally different, I'll see if I can find a pic of a 6.0 motor for ya.
Old Feb 18, 2009 | 01:26 PM
Quick444's Avatar
Quick444
Thanks!
Once I get my feet firmly planted I may start a newby thread answering some of the dumb and eventually obvious questions that people may be too scared to ask.
Old Feb 18, 2009 | 01:32 PM
superduty4x4
6.0:
I'm sure you've seen tons of shots of the 7.3 by now, but just in case you haven't:
Old Feb 18, 2009 | 01:36 PM
Quick444's Avatar
Quick444
Awesome, looks easy enough!
Thanks a bunch.
Old Feb 18, 2009 | 01:37 PM
farmb0y's Avatar
farmb0y
Great pictures! Another easy what is the badge on the door side. The only trucks to worry about being an 7.3 or 6.0 are the '03's, that's when they changed motors.
Just look under the hood, and if there is room to work on the engine, it's a 7.3; if a wrench would get stuck between the block and fenders when you drop it, it's 6.0.
Good luck with the search, take your time and be thorough! Look at a bunch of them and drive them so that you can compare.
strokersace's Avatar
strokersace
There aren't really many outward appearances that are distinct. The powerstroke badges on the door is what I look at. AGAIN - 7.3 has black background with silver or silver/red letters, 6.0 is chrome background with black/red letters. Also the mirrors - the 7.3's DID NOT have the heated/turn signal style (from the factory anyway) and the 6.0's do have the tow mirror with the heated glass and turn signal built in.
Like chase said, if you pop the hood, it's noticable. The 6.0 looks like someone took a bunch of black plastic and metal, wadded it up into a big ball, then stuffed it under the hood. The 7.3 is a cleaner looking motor compartment.
Hope that helps and good luck.
Mike F250's Avatar
Mike F250
I looked at a nice truck yesterday. 6.0 sticker was on the passenger side valve cover. tough to read as it is tucked away pretty well.
Old Feb 18, 2009 | 01:38 PM
megawatt00's Avatar
megawatt00
Alex the only dumb question my friend is the one that you don't ask!
Old Feb 18, 2009 | 01:39 PM
strokersace
I type too slow as Adam had already posted what I was saying.
EXCELLENT pics Chase!! Good visuals for what Adam and I said.
Old Feb 18, 2009 | 01:52 PM
superduty4x4
The bad thing about relying on badges, mirrors, etc. is all that stuff can be changed easily. A lot of people try to determine the early 99's by the badges being on the fenders and not the doors... well my early 99 has OEM door badges (yes, some of the early turds had door badges).
Another easy way to tell is to take a can of gasoline with you- start the truck and set the can of gasoline up near the front. I've heard that a 6.0 will stop running instantly if it even smells gas
Old Feb 18, 2009 | 01:57 PM
farmb0y's Avatar
farmb0y
Mine is one of them as well!
Once you learn and notice the little things that have been mentioned, it gets to be pretty easy to notice the 7.3L vs. the 6.0L.
Old Feb 18, 2009 | 02:08 PM
mybigredford's Avatar
mybigredford
listen to the two motors whle they are running, they sound totally different and you wont even need to look at the badges once you know which is which
Old Feb 18, 2009 | 02:36 PM
big poppa's Avatar
big poppa
Chase,s pics sumed it up good to what to look for. Also, when you do find what your looking for, check everything on it for abuse or if was well taken care of, good luck.
Old Feb 18, 2009 | 02:42 PM
machmedic's Avatar
machmedic
Also the eighth digit in the VIN on a 7.3 is "F" and on a 6.0 it's a "P".
