Clacking noises.
Old Feb 17, 2009 | 09:30 PM
vwgtivr's Avatar
vwgtivr
Clacking noises.
I'll start with the truck details
2001 F-350
7.3
155,000 miles
when the truck warms up, it has a clack or a knock, almost like a rocker arm knock.
It only seems to be when the truck gets up tp operating temp, and I get off the highway, sitting at a light at idle. I thought about the "Hutch Mod", but it only seems to be at operating temp, and sometimes when I have a full tank, so it seems to be ruled out to me.
My other questions: what does the HPOP feed? What is it's function? Could this be related? How do I check to see if the HPOP is working properly if I need to check it?
Old Feb 17, 2009 | 09:39 PM
afonda's Avatar
afonda
HPOP = High Pressure Oil Pump. high pressure oil runs your fuel injectors.
You might try putting some fuel additive in for lubricity. Might quiet ya' down a bit.
Old Feb 17, 2009 | 09:51 PM
vwgtivr's Avatar
vwgtivr
already running additives. with more reading Ifound out what the HPOP is and does. I don't think it's related anymore.
Old Feb 17, 2009 | 09:55 PM
JockD's Avatar
JockD
Can you identify which cylinder is noisy, or does it seem to be more than one?
Old Feb 17, 2009 | 10:09 PM
megawatt00's Avatar
megawatt00
What are you running for oil? Is it clean, full and the right type? I just change from dino to syn and the difference in the sound is unreal.
Old Feb 17, 2009 | 10:16 PM
vwgtivr's Avatar
vwgtivr
I just bought the truck recently, and It had a fresh oil change when I bought it. It's still clean and full. Now that I'm getting close to time to change the oil, (which I have checked religiously, to see if I had any leaks on a new to me truck) I am going to run full syn. 5w-40 is what I have read is a good all around oil in a temperate climate like Seattle.
any suggestions on weight or am I in the right direction?
I can't really decide where the noise is coming from, I want to say driver's side, but can't narrow down to one cylinder.
Old Feb 17, 2009 | 10:52 PM
megawatt00's Avatar
megawatt00
5w-40 syn is correct. The noise may be coming from the #8 injector
Old Feb 17, 2009 | 10:53 PM
rbaker6336's Avatar
rbaker6336
sounds like injector clatter,mine has done that for quite a while if I don't add oil to the fuel
Old Feb 17, 2009 | 11:18 PM
vwgtivr's Avatar
vwgtivr
why number 8?
Is it the last one in line for oil?
Old Feb 17, 2009 | 11:31 PM
megawatt00's Avatar
megawatt00
Yes that one due to design is "starved" (for lack of a better term) for oil. I run Howes in my fuel tank and after a couple of tanks it seems to be helping out.
Old Feb 17, 2009 | 11:32 PM
rbaker6336's Avatar
rbaker6336
# 8 fires right behind #6 so it gets a shortage of fuel and which lubricates it thus the clatter
I run a mixture of DK and two stroke oil ad it's a lot quieter
Old Feb 18, 2009 | 12:07 AM
vwgtivr's Avatar
vwgtivr
I'm already running RBP additive, but I'll try a little 2-stroke in it too and see what happens.
Thanks for the food for thought.
Old Feb 18, 2009 | 03:04 AM
danskool's Avatar
danskool
Go Bills !
Mine had exact same symptoms as you. Knock when warm. One morning on my way to work it started out of the blue. Never had it before. I made up a home made injector break out box and found it to be #8. I also did the In tank mod "hutch" I didn't get better. The injector is out now on the bench along with the glow plugs. Going to try a different injector. How much 2stroke oil are you guys dumping in? Additive didn't do anything for me. But forgot about the oil thing.
