Drivers brake light?
Old Feb 17, 2009 | 07:52 PM
rblaine9000's Avatar
rblaine9000
Exclamation Drivers brake light?
I have a brake light not operating and the bulb looks ok.,I replaced anyway to rule out and still no light? I am sure I seen on here about a fuse being the culpret but am not sure need help please chime on in to save the day....lol
p.s. I am going f-ing crazy...it's always something ya know?
Old Feb 17, 2009 | 07:56 PM
crum71's Avatar
crum71
1/8 mile Oval Track
Do you have tail lights? I mean does the driver side tail light work? Blinker light also?
Old Feb 17, 2009 | 10:04 PM
GK4x4's Avatar
GK4x4
lights
Hi,
Both brake lights are on the same fuse so if the passenger side works it is not the fuse. Look closely at the socket contact with the bulb out--there could be some corrosion there--scrape it clean with a knife blade. Other than that, it could be the wire behind the socket is broken off. Hope this helps--Jerry
Old Feb 17, 2009 | 10:11 PM
JockD's Avatar
JockD
Check the ground wire from the socket on that side, too.
Old Feb 18, 2009 | 08:34 AM
rblaine9000
Thanks for the input guys\,I am going to investigate today while I don't have to rush rush around (honey do).LOL Plus I can see better in daylight
Old Feb 18, 2009 | 08:52 AM
rblaine9000
I have Tail lights as well as a Blinker.... So that is what is throwing me for a loop.lol
Old Feb 18, 2009 | 08:58 AM
crum71's Avatar
crum71
1/8 mile Oval Track
That is very strange then. The blinker is the same part of the bulb(I think) as the break light....Have you had someone to press the break pedal and have a test light on the plug?
Old Feb 18, 2009 | 09:03 AM
rblaine9000
no not yet, I did not want to drive somewhere for help but that is what I am probably going to do ,I am going outside to unplug the harness to look for corosion there and re-plug in to see what I get..will reply later
Old Feb 18, 2009 | 09:06 AM
megawatt00's Avatar
megawatt00
Make sure that the ground is good. Do you hear the flasher relay when that directional is supposed to be working?
Old Feb 18, 2009 | 09:20 AM
crum71's Avatar
crum71
1/8 mile Oval Track
if it had a bad ground wouldn't that mess with the blinker some how?
Old Feb 18, 2009 | 09:28 AM
rblaine9000
Jim I have turn signal and tail light? Go figure I just checked and My fuses apear to be good, and for grins I turned on flashers and no go left side out......so does this point back to a fuse issue or is there a broken wire somewhere from the triple split? It is hard to investigate with my book because it is not for specific year and make it is for 2000 excursion
megawatt00's Avatar
megawatt00
Yes it would Scott. A bad ground won't allow the electricity to return.
Old Feb 18, 2009 | 09:31 AM
rblaine9000
I could theoreticaly turn on my hazzards and then check with a test light then that would be the same as someone holding the brake pedal?
Old Feb 18, 2009 | 09:37 AM
rblaine9000
Jim I turned on hazzards and pulled out plug then checked with my test light and to my astonishment ( if that is spelled right) the light was blinking.....LOL so you hit the nail on the head!!!!thanks ol' buddy.
NOW where does this ground at?
Old Feb 18, 2009 | 09:54 AM
megawatt00's Avatar
megawatt00
Your more than welcome Blaine. I'm not 100% sure where the ground connects. I think that they connect together under the truck near the trailer light setup.
