302 to 351w
Old Feb 17, 2009 | 06:56 PM
smbikes's Avatar
smbikes
302 to 351w
i have a 77 f100 that is in real good shape with a 302 , A/C and power steering but i want to put a 351w in it, what will i need to do the swap ?
Old Feb 17, 2009 | 10:06 PM
fastfarmer's Avatar
fastfarmer
Pretty much a bolt-in. Motor mounts, bell housing is the same, most of the accessories bolt up, exhaust manifolds are the same but will be a little farther apart and a little higher on the engine because the 351W block is a little taller. I belive the interchangeability of the flywheel/flexplate depends on the year.
Old Feb 18, 2009 | 11:15 AM
loudfords's Avatar
loudfords
You will need a different power steering mount and a new y-pipe. The alternator mount will fit both engines. Flywheels only changed on the 302 after 81, so your 77 flywheel will fit any year 351w. Easy fun swap!
