Anybody using these IC boots?
Old Feb 17, 2009 | 01:23 PM
hucka1a's Avatar
hucka1a
Are these a good replacement, or should I buy from dieselsite?
Diesel Power Products | Ford Powerstroke | 99-03 7.3L | Intercoolers & Hoses | Silicone Re-placement hoses | OH110Ford | 3" i.d. Hump Hose 4" long
Thanks
Edit, lets try this, http://dieselpowerproducts.com/catal...se-4-long.html
Old Feb 17, 2009 | 01:31 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Don't see a link Huck.
Old Feb 17, 2009 | 01:32 PM
hucka1a's Avatar
hucka1a
Try it now Rick. The site is being screwy again.
Old Feb 17, 2009 | 01:35 PM
indebt's Avatar
indebt
I have a set (1.5yrs - black) They are good quality and inexpensive. I recommend them alot....
Old Feb 17, 2009 | 01:38 PM
miller_feed
I thought the boots at the IC had a little bigger end to fit the IC, with a little smaller end to fit the tube?
Old Feb 17, 2009 | 01:44 PM
indebt's Avatar
indebt
IIRC thats only if you did the 6.0 IC......
Old Feb 17, 2009 | 01:49 PM
miller_feed
Thanks Jorge, as many times I have taken mine off, I should remember. I must be getting old.
Old Feb 17, 2009 | 02:04 PM
indebt's Avatar
indebt
...... I must be getting old.
yup, and we are all infected........
Old Feb 17, 2009 | 02:11 PM
jdecker88's Avatar
jdecker88
I am split between those that Clay can get (diesel power) or the BD ones that Xtreme Diesel has for a 180 with all the clamps. I know your limited on your selection though Huck but you could just upgrade to a late model turbo .
Old Feb 17, 2009 | 02:38 PM
Riffraff Diesel's Avatar
Riffraff Diesel
PREMIUM SPONSOR
I have a late model Turbo and spyder if you are interested Huck... I can also get those boots for you... Contact me and I can help you out. BTW- Are you going with the Terminator HPOP or the Adrenaline?
Old Feb 17, 2009 | 02:50 PM
hucka1a's Avatar
hucka1a
Thanks Clay. I'll pm you the info. I'm gonna hang on to my little turbo for awhile. I'm not sure yet on the HPOP. It's gonna be awhile before I can change it.
Old Feb 17, 2009 | 03:22 PM
F250_'s Avatar
F250_
Those boots are the same material used for the ones on my IC swap out, but mine are not the hump design. From a purely material quality standpoint, I'm impressed with them... much better than the stock boots.
Old Feb 17, 2009 | 03:30 PM
Riffraff Diesel
PREMIUM SPONSOR
With your engineering background, what is the thought behind the hump?
Old Feb 17, 2009 | 03:33 PM
superduty4x4's Avatar
superduty4x4
Late model turbo and spyder? I might bite... PM me if you want.
Old Feb 17, 2009 | 04:24 PM
danskool's Avatar
danskool
Go Bills !
YUP,Got my boots off now. two upper boots are 3"id 4" long.
The lower boots at the cooler are 3"id(tube) on one end and i think 3.375(cooler) on the other end(+- tough to tell exactly) . 5.5 inches long. A difference in the two lower boots for sure on size from the uppers..
