9" rear end question?
Old Feb 17, 2009 | 01:10 PM
IrishBusDriver's Avatar
IrishBusDriver
I brought in an old truck or should I say 1/2 a truck and is has the 9" rear in it. The nubers stamped on it are " 3L70". I am thinking it should be a 3.70 ratio, but what about the "L"? Thanks, Mike
Old Feb 17, 2009 | 01:12 PM
joestratton1's Avatar
joestratton1
limited slip
Old Feb 17, 2009 | 07:12 PM
IrishBusDriver
Does that mean the same as a Posi-trac? I have several 9" rears and a couple of them are the 3.70 ratio, but this one has the "L". If it does mean posi-trac, do or would I need any thing special { certain type grease, etc. } if I put this "stump" in another truck? Thanks, mike
Old Feb 17, 2009 | 10:11 PM
Franklin2's Avatar
Franklin2
posi-trac, positive traction, limited slip, whatever you want to call it. It's the factory version with the clutches inside the rearend. Get someone to hold one axle while you try to turn the other. If it turns easy, they are worn out anyway. There should be some drag or resistance when one axle is held while the other is turned.
They have a tube of special additive you can buy for it, but I have never figured out what it really does. I had limited slip front and rear on my 80, and a guy gave me a tube of that stuff, but I never got around to putting it in, and I never noticed any problems with it.
Old Feb 18, 2009 | 04:34 AM
IrishBusDriver
Thank you for the reply, I have worked with many 9's ,but had not came across one like this. I thought that is what it amounted to ,but I like to be sure. Again thank you for the reply, Mike
Old Feb 18, 2009 | 04:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The front/rear ends prolly had the additive mixed in. You would soon find out if the additive wasn't there!
XL3 (replaced Ford part number: C8AZ19B546A) .. Friction Modifier Additive-4 oz bottle.
MSRP: $4.99 // FTEpartsguy.com price: $4.49.
Every Ford: Equa-Lok, Traction-Lok, Power-Lok, whatever you want to call it....requires this additive.
Drive without it...it won't be too long before the lined clutches overheat and burn up.
