Rear Diff I.D.
Old Feb 17, 2009 | 10:17 AM
biglugnutz's Avatar
biglugnutz
Rear Diff I.D.
I decided to keep my 56 F-350 Firetruck and turn it into a rampback car hauler for my 62 Chevy II. Problem is... It goes about 52 MPH at 3500 RPM. The VIN says the rear is 5.14:1 rear ratio. With 13000 original miles, I would love to save this rear and regear it.
How do I identifiy this rear end
Thank you!!!
Tim
Old Feb 17, 2009 | 10:36 AM
Julies Cool F1's Avatar
Julies Cool F1
There may be a metal tag on it - about 3/4 inch wide and 2 inches long. If not can youget a picture of it?
Old Feb 17, 2009 | 12:13 PM
mechmagcn's Avatar
mechmagcn
On a F350 it should be a Dana 70. Look on the lower cast rib on the center section, there will be a 70 cast into it.
Old Feb 17, 2009 | 01:27 PM
stockcar nut's Avatar
stockcar nut
The best way to get a better gear ratio is get a later model one ton axle, Better gear set PLUS way more common eight lug hubs and wheels. I scored two axles, one is a '75 and the other is a '81. Either one is a bolt in. I also scored the front hubs, brakes and spindles for both my rear axles. I intend to put these on the '54 front axle. Makes the brake systems match as well as getting the wheels the same. Tom
Old Feb 17, 2009 | 04:05 PM
biglugnutz's Avatar
biglugnutz
I realize that a later model axle would be the way to go, but I want to reasearch the old one to try to keep the brake systems and driveshafts easier to hook up.
I found a tag on the passenger side rear of the housing.
Model is B 100 NX.
Ratio 5.143:1
Serial # is pretty illegible
On the left of the tag is a black triangle with a large "T" in the middle with a smaller "D" on the left of the "T" and a smaller "A" on the right of the "T", and a smaller yet "CO" below the "T".
Any help??
Tim
Old Feb 18, 2009 | 01:06 AM
Julies Cool F1
WOW! Sorry I asked!
Man that's greek to me....This is a job for (Ta ta ta da) Number Dummy!
Oh Bill!!!!!!!!!
Old Feb 18, 2009 | 01:24 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Model is B 100 NX.
Ratio 5.143:1
On the left of the tag is a black triangle with a large "T" in the middle with a smaller "D" on the left of the "T" and a smaller "A" on the right of the "T", and a smaller yet "CO" below the "T".Any help??Tim
It's greek to me too, Julie. However.....I have the parts catalog.
TIMKEN Model B 100 NX - A1534 / 7,200 lb. Rear Axle Capacity.
Three ratios were offered: 4.86-1 / 5.14-1 / 5.83-1.
Applications: 1956 F350 // 1957/58 F350; P350/400 // P Series: Parcel Delivery // 1957/58: This info is from the 1957/63 Ford Truck Parts Catalog.
1948/56 Ford Truck Parts Catalog / Volume I-Text ~ Rear Axle Parts List # 77 // Volume II-Illustrations ~ Illustrated on page 93.
Originally Posted by mechmagcn
On an F350, it should be a Dana 70...
No Spicer (Dana) 70's in F350's (or anything else) until 1961.
