93 F150 problem, need help
Old Feb 17, 2009 | 06:17 AM
wdstang's Avatar
wdstang
Alright heres the problem, its a 302, the #8 cylinder is burning up the plug, but only when i put a load on the truck( 4 wheeler and small trailer) and once it gets into o/d. i have swapped injectors, changed fuel filter, checked fuel pressure(32psi@idle), checked for intake leak, just recently rebuilt motor and had the heads done, it was doing this before the rebuild, it does it on both tanks also.Also have the egr blocked off now after rebuild.I know it has to be leaning out #8 somehow, i am stumped on this one!!!! any help appreciated.Thanks
Old Feb 17, 2009 | 06:43 AM
Lazy K's Avatar
Lazy K
The obvious question is are you using the correct type of spark plug and the right heat range? The next thought is just a guess but the positive crankcase vent system may have an effect on No.8. You could try disconnecting it and plugging it at the manifold/throttle body.
Old Feb 17, 2009 | 07:16 AM
wdstang's Avatar
wdstang
Yes they are autolite 25's,
Old Feb 17, 2009 | 11:35 AM
dbuck50's Avatar
dbuck50
Re-route the PCV from the back of the plenum to the center at the vacuum tree. It is dumping gases right into the #8 cylinder. The did this fix in later years as everyone was having issues with burning the rings/piston in the #8. Simple fix, but some damage may already be done. It melted my #8 piston on my 93 5.0.
Old Feb 17, 2009 | 01:00 PM
wdstang's Avatar
wdstang
Thank you!!!
Old Feb 17, 2009 | 01:40 PM
quicklook2's Avatar
quicklook2
also, are your plug wires routed correctly?
Old Feb 18, 2009 | 11:11 AM
FireMe's Avatar
FireMe
+1 on the plug wire routing. If you're running the 'even' firing order, make sure #7 and #8 plug wires don't run next to each other.
Old Feb 23, 2009 | 06:30 AM
wdstang's Avatar
wdstang
yeah the pcv change didnt work, the wires are next to each other, i will move them and try that.Thanks for the input everyone.
Old Feb 24, 2009 | 07:04 AM
wdstang's Avatar
wdstang
Learn something new everyday,dam plug wires!!!!!!!!!!!!!!!!
Old Feb 24, 2009 | 08:12 AM
alan18's Avatar
alan18
help transsmition problem
hi i have a 93 f150 with the 5.0 and the e40d transsmition but every time i take it out when it is cold it will shift through all of the gears on its own but when it warms up i have to shift it in to drive and overdrive manualy help!
Old Mar 8, 2009 | 11:11 AM
fordguy2009's Avatar
fordguy2009
i have the same problem, alan... maybe they will help us..?
