Sensor?
Old Feb 16, 2009 | 12:24 PM
tannebi's Avatar
tannebi
Sensor?
I have a 1999 F-250 Ford Diesel. I live on the MS Gulf Coast the tempature and humidity is usually pretty hot but when it gets below 50 degrees the truck will not run worth a crap. Even when the truck warms up it does not change the performance, but when the actual weather warms up it will run fine. I want to think its some type of sensor but I really just don't know. If anyone has an idea please let me know what it might be.
Thanks, tannebi
<!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Old Feb 16, 2009 | 12:37 PM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Thanks, tannebi <!-- / message --><!-- BEGIN TEMPLATE: ad_showthread_firstpost_sig --><!-- END TEMPLATE: ad_showthread_firstpost_sig -->
Welcome to FTE.
We need a little more info on the truck and what the definition of (will not run worth a crap) means? Is it lack of power, or seems to miss? Hard to know what is happening from what you wrote. Do you have any mods?
Old Feb 16, 2009 | 12:45 PM
tannebi's Avatar
tannebi
Originally Posted by miller_feed
Welcome to FTE.
Lack of power, you actually have to let off the accelarater for it to shift gears. It is automatic transmission.
Old Feb 16, 2009 | 04:07 PM
megawatt00's Avatar
megawatt00
Welcome to FTE. Is there a SES light on? Have you checked for codes?
Old Feb 16, 2009 | 06:28 PM
vlbroome95's Avatar
vlbroome95
I also live on the MS Gulf Coast. Where are you purchasing your fuel? Could be time for a new fuel filter.
Old Feb 16, 2009 | 06:40 PM
F350-6's Avatar
F350-6
Welcome to FTE tannebi and vlbroome95.
Good quality fuel, clean full oil, and filters that are in good shape are important. If you want to find a bad sensor, you really need to get the truck on a scanner. Otherwise you'll just end up throwing parts at it. Stay away form the auto parts stores free scans, they won't work on our trucks. You need a shop to scan it for you and run a couple of tests with the scanner to try and trip any other codes.
That is unless you can find someone near you that has a scanner that will check it out for you.
sddesigns
New Jersey Chapter
Apr 14, 2010 01:55 PM
sddesigns
New Jersey Chapter
Mar 24, 2010 11:43 AM
sddesigns
New Jersey Chapter
Mar 15, 2010 02:29 PM
sddesigns
New Jersey Chapter
Jan 28, 2010 05:46 PM
