New pics- let me know
Pictures by rhino_160 - Photobucket
1.) the front tv is a kenwood DNX5120 i got from sonicelectronix.com for $649.99 plus shipping ($599.99 now!!!!!)- you can't beat their prices. their customer service is awesome. i thought mine was messed up so i called them and they sent me a shipping label that very minute to get another one. (problem was a wire came loose when i pushed it back in the dash, crimp did not hold, my fault)
i did have to mod the dash a bit to make it fit perfect. the tv itself will slide right into the opening if you do not use the provided bracket. problem is, anyone can just slide it back out. i took the front panel off and behind it is a black plastic wall with the square from the factory cut out. i just dremeled about and inch off the top to so the mounting bracket would fit and there you go, perfect!
2.) the safe is made by Homak and fits perfectly where the old factory cd changer was. just pull out the center console "shell" that is on the inside and mount the safe with some bolts. just pop it back in and you have you a small gun/money/jewelry safe. it is all digital and takes 4 AA batteries plus has a 9 volt battery backup. works awesome. here is the link, even though it is showing out of stock: Amazon.com: HOMAK HS10036683 Electronic Access Pistol Box, 10-Inch by 3.5-Inch by 7.5-Inch: Home Improvement
if you have any other questions let me know
