Wiring harnesses?
Old Feb 15, 2009 | 04:51 PM
Chachi568's Avatar
Chachi568
Wiring harnesses?
I am going to be buying an aftermarket wiring harness for my 49 Merc, and would just like to know which ones everybody liked or disliked, and for what reasons. It will have a 351W and C6, not sure if that affects anything.
Take er easy
Old Feb 15, 2009 | 06:23 PM
B/B ford's Avatar
B/B ford
Clean & Classy
I really like my Ron Francis wiring harness. It leaves nothing to be desired and covers all wiring needs now and in the future. It is quite expensive but worth it to me.
Old Feb 15, 2009 | 06:28 PM
grumpy46's Avatar
grumpy46
ron francis is more expensive but to me it was a lot easier.
Old Feb 15, 2009 | 06:44 PM
56panelford's Avatar
56panelford
Has anyone on here tried the EZwire, I've been concidering the EZ21 wiring kit, $185.00. I see the adds all the time in the truck magazines.
Old Feb 15, 2009 | 07:27 PM
LEckart's Avatar
LEckart
Iive used both EZ Wire and Ron Francis. There is a good size difference in cost but the EZ wire will do the job. One thing I liked about the RF kit is the wires are not pre-terminated in the fuse panel and it makes it easier to run them. Both are good kits just more bells and whistles and perhaps better instructions in the Ron Francis.
Old Feb 15, 2009 | 08:25 PM
Julies Cool F1's Avatar
Julies Cool F1
Alot of th eguys also like the Painless wiring harness from Summit racing.
Myself, for $185 I can buy all the wire, good connectors and fuse blocks I need to wire from scratch and build a custom harness as I go. I have trouble tracing down premade harnesses.
Old Feb 15, 2009 | 08:47 PM
TxF100's Avatar
TxF100
I have used the Painless system on a couple of cars and have nothing but good things to say about them. Good instructions and well made parts.
Old Feb 15, 2009 | 08:49 PM
skuzzel_butt's Avatar
skuzzel_butt
i used a kit by american autowire. very well made. its priced in the middle of a ron francis kit and ez wire kit.
Old Feb 15, 2009 | 08:53 PM
dongc1's Avatar
dongc1
I have installed 2 EZ Wire harnesses and found them to work out real well.
Old Feb 15, 2009 | 09:07 PM
3golfjack's Avatar
3golfjack
If you are using a 302 engine with a EFI setup can you use a ezwire system?
Old Feb 15, 2009 | 09:56 PM
dongc1's Avatar
dongc1
I used a EZ Wire in a truck with a TPI SBC. All of the wiring for the fuel injection is separate from the truck wiring harness. You will have to make or buy all of that wiring in addition to any wiring harness that you buy AFAIK.
Old Feb 15, 2009 | 10:22 PM
Ford52F2's Avatar
Ford52F2
I did it Julies way, that way you can use shrink wrap and custom build. I had an unlimited supply of different size wrap that were 30 feet long. Just make sure that all the wire is in the wrap. Forgot the horn and backup light wire.
Regards, Dale J.
Old Feb 16, 2009 | 01:22 AM
Julies Cool F1
Regards, Dale J.
Old Feb 16, 2009 | 07:42 AM
Walston's Avatar
Walston
I used the ezwire for our 60 and was very happy with it.
Old Feb 16, 2009 | 07:46 AM
john fin's Avatar
john fin
Making harness
I am with Julie, simple and cheap to make your own. Here is a 49' harness I am making using the old one as a pattern. Replacing old wire with modern cloth covered(vinyl inside) wire. Pics make it look like a bad job but its not.
