Sponsored by: Real Truck
Blinker Problem. Please help
Old Feb 15, 2009 | 03:55 PM
plowtruckf350's Avatar
plowtruckf350
Hello,
I have a 2001 Single Cab F350 Diesel.
My blinkers blink until I touch the brake then they go solid. My hazard flashers however work fine when engaged. I noticed when the blinkers are on the cargo brake light blinks. I am getting reverse feedback somewhere in the system. Any idea where?
I thought it may be the tow hitch, So I disconnected it next to the spare tire. Still no luck.
Please help!
Jeff
Old Feb 15, 2009 | 07:18 PM
dkstuck's Avatar
dkstuck
Check all light bulbs
Old Feb 15, 2009 | 07:20 PM
plowtruckf350
Light bulbs have all been replaced. No luck.
Old Feb 15, 2009 | 07:43 PM
dkstuck's Avatar
dkstuck
Check wiring harness for wear n tears, also check all your grounds. May want to unplug one light at a time with brakes on an see if you can pin point that way. Could be in steering harness/turn signal switch,, just not sure
Old Feb 15, 2009 | 07:46 PM
plowtruckf350
This happened last year as well, and on my way to St. Louis (1,000 mile trip) it fixed itself. Now 5 months later, its back again.
Old Feb 15, 2009 | 07:53 PM
dkstuck's Avatar
dkstuck
I'm thinking you may have a plow on your truck,,, Some times I amaze myself,,, Have you unplugged your plow lights? I'd check harness real close for damage, does seem like a bad ground. I haven't fooled with the newer trucks,, just deal with older so I'm probably missing some things here
Old Feb 17, 2009 | 05:37 PM
Beerstalker's Avatar
Beerstalker
What cargo brake light are you talking about the factory one on the cab, or one on a topper/cap? If you have a topper/cap the 3rd brake light may be wired up wrong.
