Sponsored by: Real Truck
Electric brake wiring problem
Old Feb 15, 2009 | 03:36 PM
brunor's Avatar
brunor
I have purchased a used 2004 Ford F250 that came with a brake controller, the standard 7pin rv connector and a 6pin goose neck connector in the bed. When I tow using the 7pin to 4 flat adapter everything is fine. When I plug my RV in to the factory 7pin connector and press the brake my speedometer goes to 10mph and the doors lock as if I were moving but I'm not moving at all. It does this in any gear position except reverse. I have not tried anything yet hoping some has seen this issue and can tell me how to fix rather quickly. Any help would be greatly appreciated.
Thanks
Old Feb 15, 2009 | 06:55 PM
crw f250's Avatar
crw f250
Sounds like a bad ground to me. I would check the 7 pin plug first on the front side,loose wire or maybe the gravel cut a wire off. Did you just grease the trailer ball? Colin
Old Feb 15, 2009 | 08:04 PM
DPorter's Avatar
DPorter
There are two wiring patterns for the 7 pin connectors. One of the pins that changes is the brake power pin. I bet the truck is wired one pattern and the trailer is the second pattern therefore causing weird stuff to happen.
