How do I fix this code??
Old Feb 15, 2009 | 09:53 AM
stroke-of-luck00's Avatar
stroke-of-luck00
I just loaded up the ASE tune from the Spartan archive. I'm getting a code P1102 which apparently is an <ACRONYM title="Mass Airflow Sensor">MAF</ACRONYM> error. Low air flow or something like that. any idears on how to remedy the problem so I'll stop throwing codes?
also, i don't really romp on it too much so with normal driving, should i worry about heads, tranny, etc etc??
Old Feb 15, 2009 | 10:37 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Not sure about the code but I ASSUME you installed gauges before you tuned it, so just keep a close eye on your boost gauge so it doesn't get over 30 psi and you *should* be OK. Same goes for the tranny temp gauge. Mine hasn't gone over 160 but the range is 160-190, trouble starts over 210* HTH-Tim
