1966 - 1977 Early Broncos
351windsor with major problems
Old Feb 14, 2009 | 08:50 PM
farmall hcrazy's Avatar
farmall hcrazy
Question 351windsor with major problems
Hi yall I have a 351windsor and I had to put a new distributer in it, got it running and now the motor is shaking realy bad(not from a broken motor mount or stand) and it is back-fireing(but no matter where I turn the distributer it pretty much runs the same) what could be the cause. P.S. On a auto light 2100 carb is the vacume advance supossed to hook-up to the upper or lower vacume piece.
Old Feb 14, 2009 | 09:55 PM
Conanski's Avatar
Conanski
Sounds like you messed up the firing order, it should be 13726548 with cyl #1 on passenger side front and the distributor turns counterclockwise.
Old Feb 14, 2009 | 10:07 PM
farmall hcrazy
I have my firing order correct and it won't stay running unless you give it the gas.
Old Feb 15, 2009 | 11:57 AM
RCrawler's Avatar
RCrawler
I agree with Conanski. Double check your firing order first.
Is is an electronic or points type distributor? Are your points set correctly?
The dist should be hooked to manifold vacuum.
Jason
Old Feb 15, 2009 | 07:13 PM
68 351 bronc's Avatar
68 351 bronc
I bet your off 180. Pull number one plug and bring it up on compression first. Then pull your dis and drop it in right.
Old Feb 15, 2009 | 08:47 PM
RCrawler's Avatar
RCrawler
Where have ya' been? Haven't seen you around much lately?
Jason
Old Feb 15, 2009 | 09:22 PM
farmall hcrazy
So how can the truck run 180 out. But it does shake vilently, back fire, and can't stay running unless you give it some gas.
Old Feb 16, 2009 | 09:42 AM
68 351 bronc
Jason
My 68 turned into my daily driver for about the last 9 months so no new mods. The 01 F250 I bought new still hasn't had a single problem other than the rattle that brought me to this site 8 years ago.
Old Feb 16, 2009 | 11:01 AM
RCrawler's Avatar
RCrawler
It may still run, but it is attempting to fire in the wrong cylinder sequence. On an 8 cyl engine, there is a cylinder firing every 90* of crank travel. So there is more of a chance to get one to fire at the right moment to make it run. Getting a 4 cyl to run 180* out is not as likely.
Jason
Old Feb 16, 2009 | 11:05 AM
RCrawler's Avatar
RCrawler
Well, that's a good thing that you haven't had any problems then.
Jason
