under the hood
Old Feb 14, 2009 | 07:20 PM
racoonbandit's Avatar
racoonbandit
under the hood
Hello,
I am in the process of trying to finish my hood and get it ready for paint. I sanded under the hood and was wondering if I could put some type of heat shield under the hood. I have used that stuff for roofing in the cab from Home Depot. It has a aluminum top side with a tar type of product for the underside. Would that be okay for under the hood or would the heat from the engine be to hot for it. I don't want it to melt or start a fire once I have the truck back on the road. Any suggestions ?
Old Feb 14, 2009 | 08:51 PM
Julies Cool F1's Avatar
Julies Cool F1
I'm not sure I'd use a Home product for a vehicle application, especially since it has a petrolium substance in it.
House temps never get much above 130 degrees - even in an attic in the summer. Temps under that hood will regularly get above 200 degrees.
I would look into automotive insulation - check withthe rod shops of 4WD places.
Old Feb 14, 2009 | 09:57 PM
Kusto's Avatar
Kusto
This may seem like a silly question, but why would you want to insulate under the hood?
Old Feb 15, 2009 | 12:16 PM
racoonbandit
I guess I was looking for more of a heat barrier.
Old Feb 15, 2009 | 01:06 PM
Kusto's Avatar
Kusto
I agree with Julie, a residential product would never work in that application and would likely cause a fire or at very least create a huge mess.
Why are you trying to keep heat in your engine compartment? The less heat in there the more hp and fuel economy you will get out of your engine as cold air is less dense than warm air improving the stoichiometric ratio, thereby increasing hp.
