Sponsored by: Real Truck
Spare wheels
Old Feb 14, 2009 | 02:09 PM
captain_trucks's Avatar
captain_trucks
Spare wheels
Hello everyone,
I have two questions.
First, what year did they start with the tire pressure sensors?
Second, I have purchased another set of wheels for my 08 SD. I do not know if the sensors are there or not, if I have to install the sensors will they automatically work with the truck or do I have to train them. The truck came with 18" and I have aggressive tires for winter. I purchased a set of aluminum 20" for summer treads, so I do not want to have to break the tires down everytime I switch wheels, so I will install sensors on the 20's if they are not there.
Thanks
Jeremy
Old Feb 14, 2009 | 05:58 PM
carls 250's Avatar
carls 250
08 Was acrossed the board if the wheels came off of a 08 they should have them. Look @ the valve stems you can see a diff.
Old Feb 14, 2009 | 06:53 PM
WeWonIt's Avatar
WeWonIt
My 08 has no sensors, it came that way?
Old Feb 14, 2009 | 08:20 PM
PowerStrokeHD's Avatar
PowerStrokeHD
'08 was the first year for TPMS, but it did not start till Job 2 which would be trucks built on or after 07/30/07.
There is a potential problem with what you plan on doing though. The TPMS is set to monitor the pressure of the factory installed 18" wheels which are set to a certain pressure. When you put on the 20" wheels which will require a lower pressure when compared to the current 18" tires there is a high probability that it will set a low pressure warning even if the sensors are there or you have them installed. The sensors used are the same for the 18" and 20" wheels as the low pressure set points the TPMS system is looking for is stored on the vehicle in the ICM and not the sensor its self. The sensor only transmits the current pressure...
Old Feb 17, 2009 | 04:50 PM
Beerstalker's Avatar
Beerstalker
I thought that some of the guys here figured out that the system just looks for a difference in the readings of the sensors. So if one tire was 10psi (just a made up number not sure what it really is) lower it would turn on the light. If all tires were set to the same lower pressure the light does not come on. I could be wrong on this, but I'm pretty sure i read that here somewhere.
Old Feb 17, 2009 | 07:59 PM
captain_trucks
The 20's actually require a little more pressure than the 18's.
Old Feb 17, 2009 | 09:38 PM
PowerStrokeHD
I could have swore it was the other way around. I know that the 20's require 65 psi at all corners, but thought the 18's require more, especially in the rear...
Old Feb 18, 2009 | 06:46 AM
captain_trucks
My 18's are 65 and the 20's I just bought say 80 for single wheel use They are Wrangler's.
Old Feb 18, 2009 | 09:23 AM
MassSupra's Avatar
MassSupra
That is how most systems work. You shouldn't have a problem setting the new sensors for the 20's as long as the relearn procedure doesn't require a scantool.
