Im Frustrated
Old Feb 14, 2009 | 09:19 AM
brownlee03's Avatar
brownlee03
Im Frustrated
Ok off the bat I wanted to say is I'm in love with my 86 F150 302. I bought it when it was five years old and I have had it since.
The problem I'm having is that the engine cuts off while I'm driving. It doesn't sputter or slowly dies it just dies with no warning. It has done it at slow speeds and high speeds.
Things I have replaced: ECU, Emissions Module, Ignition Coil, Fuel Pump, Fuel Filter, Throttle Position Sensor, EGR Position Circuit, TFI Module
I have pressure on the fuel rails and lots of spark, Im stuck!
Old Feb 14, 2009 | 10:14 AM
bmuhlbach's Avatar
bmuhlbach
distrutor module they do all kinds off weird things if going bad ?Plug wires sometimes my Bronco would shut off ussauly change wires and it be fine.
Old Feb 14, 2009 | 11:33 AM
victorcharlie's Avatar
victorcharlie
Maybe the ignition switch?
Old Feb 14, 2009 | 12:10 PM
Bern_F150_4x4's Avatar
Bern_F150_4x4
TFI or module in the distributer. My 300 has been thru two TFI's and one distributer module. Most auto parts stores can test them but your problem sounds heat related. Get a distributer from the junkyard and see if the problem goes away.
Old Feb 14, 2009 | 01:48 PM
brownlee03's Avatar
brownlee03
Looking at the wiring diagram the ignition switch is connected to the EEC Relay which leads into the injectors.
Old Feb 14, 2009 | 07:54 PM
bashby's Avatar
bashby
So when it shuts off you have cranked itand checked for spark at the plugs and fuel pressure. Next give it some fuel (spray some carb cleaner down the intake) and see if it will run. If it does and it shuts off when you stop adding fuel, then the injectors arent firing.(you said you had fuel pressure). Then check for power to the injector, I believe the eec power relay supplies power to them as well as the coil. the computer then grounds the injector to energize it
