Hard Starting Flathead:
Old Feb 13, 2009 | 11:13 PM
leonharu's Avatar
leonharu
My truck spins over and over before it starts up!It runs fine after it starts.I took the cap off distributor and lined the timing marks up and the points are not even close to opening?Is this normal?Is my timing off that bad or what else could be wrong?Like I said it runs great after it is running.
Old Feb 14, 2009 | 12:19 AM
Julies Cool F1's Avatar
Julies Cool F1
I don't know about the points, but is almost sounds like it's taking a few seconds to pump fuel up to the carb to start the engine. Before you start it, take th eair cleaner off and open the throttle....Is gas being shot into the carb? If not then the fuel is probably falling back toward the tank.
If there is fuel spraying in then it's probably something else.
Old Feb 14, 2009 | 02:15 AM
55 f350's Avatar
55 f350
are the points adjusted right ? the cheap ones with the plastic rub blocks are bad about wearing out quick . if they aren't opening , there's the possibility that maybe , and i have had this happen on other brands , that the pin in the drive gear of the dizzy has let go and it isn't spinning .. bad coil ? i'd check that for sure too. i chased gremmies for a long time in mine , hard to start when warm , zonking out in traffic , etc. and it was the dain coil was bad . after that like julie said start checking the fuel system .
Old Feb 14, 2009 | 09:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
I think Julie is correct, if this is a situation that happens after an overnight rest. A lot of times this happens when the fuel all drains away from the carb bowl thru a ruptured power valve or one that is leaking at its gasket. If you take the carb off the engine, pull off the top cover section of the carb, and set it on the bench. watch over a period of a couple of hours whether a full bowl of fuel drains away (it will come out the bottom, so set it in a pan or something).
Old Feb 14, 2009 | 09:38 AM
havi's Avatar
havi
I'll have the Roast Duck
Bad points will not allow it to run great after it is running. So you probably have the fuel starve issue that Julie and Ross mentioned. my $.02
Old Feb 14, 2009 | 01:00 PM
HD74's Avatar
HD74
I'm with Julie on this one. You might think about installing a E-type fuel pump.
Old Feb 17, 2009 | 08:26 PM
leonharu's Avatar
leonharu
This start-up is after the engine is hot and been setting for about 15 minutes or so.Dumb question-is there anyway the distributor can be off a tooth.For some reason I can't seem to get the timing set where the truck runs and cranks good.I have dual exhaust on truck and when I put the timing where it suppose to be I get a funny popping sound out of the drivers side exhaust pipe and the idle is rough.
Old Feb 18, 2009 | 03:59 PM
HD74's Avatar
HD74
What about a vacuum leak???
Old Feb 19, 2009 | 06:54 PM
leonharu's Avatar
leonharu
I set the timing with a light !!!!!The truck runs good,but still have a rough idle and is hard to get started sometimes.It cut off with me one time starting off and I had to grind and grind to get it back running.I think the light is useless!
Old Feb 23, 2009 | 05:52 PM
leonharu's Avatar
leonharu
After I actually set the timing with a light right on the money,now my truck is very hard to get started.I have to move the distributor clockwise a bunch before the idle smooths out and the motor cranks better.What could be wrong here?I thought once I used a light that everything would be better-wrong!
Old Feb 23, 2009 | 06:02 PM
havi's Avatar
havi
You may want to verify top dead center first, and see if the dist. is lined up correctly. Just a thought.
Old Feb 23, 2009 | 09:04 PM
leonharu's Avatar
leonharu
Are you saying that the distributor might be off a tooth?Is this possible?What is the easy way to find TDC?
Old Feb 23, 2009 | 09:18 PM
havi's Avatar
havi
Taking a step back, did we verify that fuel delivery is good?
Old Feb 23, 2009 | 09:49 PM
leonharu's Avatar
leonharu
Yes,but that should not have anything to do with timing problems should it?The truck runs down the road and pulls strong.No problems with fuel delivery.
Old Feb 23, 2009 | 10:38 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Is your truck still 6v? If so, I would replace the condenser and see if that helps.
Next time it's being cranky, squirt a little gas down the carb, put the air cleaner back on, and try it. If it tries to fire up, it's a fuel problem. If not, it's ignition, either a condenser or coil problem most likely. Check the spark at the coil when it is being obstinate. See if the coil is hot.
