Aftermarket Products
Sponsored by: Worksport
Clear Corner Lens
Old Aug 6, 2002 | 09:02 PM
scooby3_4's Avatar
scooby3_4
Clear Corner Lens
I have a 1997 Ford F-150 4X4 ext the clear coner that i order for it are different the the side marker i have now my sidemakers have 3 screw holding the lens in the headlight assembly and the clear corner have a hole for one torx screw to go in the top which mine dont have and two pegs that look like they go in the right place has anyone seen this problem i am lost the corner say it for a 1997 f_150/250
Old Aug 7, 2002 | 11:49 PM
Maximua172's Avatar
Maximua172
Clear Corner Lens
Old Dec 31, 2004 | 09:39 PM
1993_f150's Avatar
1993_f150
I ran into this problem also. I bought my cousin some after market clear headlights for his 97 f150 and they did not fit as well. the problem was that his was a early model 97 and they changed some of the options about the middle of 97. so most of the parts are for the later 97 model. Try to find one that matches the product number. Hope it helps
Old Jan 1, 2005 | 05:13 PM
Smaug's Avatar
Smaug
They changed the header panel in 7/96. Don't know why. Do a search on ebay for early 97 F150 corner lights. They usually run about $10-15 more than the other ones.
Old Jan 3, 2005 | 12:23 AM
97Centurion's Avatar
97Centurion
Rub my Belly
I had the same deal with mine. Changed my header panel and a few misc parts. Just the parts to do thew change over was about $130 not including the headlights and corners but now I have more options in what I can install as far as headlight and corners styles.
