Knock sensor obsolete part?
Old Feb 13, 2009 | 03:08 AM
MaryfPoppins's Avatar
MaryfPoppins
Hopefully this will be simple to answer. We dropped the 4.9L 6cyl from a '91 F150 into a '94 F150. The knock sensor got broken and when we went to get a new one we were told it is an obsolete part and can't get one. Is this true? Thanks for the help.
Old Feb 13, 2009 | 07:30 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Try an auto parts store, I assume you asked the dealer and that's the answer you got?
Old Feb 18, 2009 | 01:35 PM
MaryfPoppins
Does O'Reilly's qualify as an auto parts store? Cause that was the first place we went. I was looking for a more experienced point of view that's why I posted the question here.
Old Feb 18, 2009 | 05:23 PM
krewat's Avatar
krewat
You're better off asking the question in the appropriate engine forum.
Old Feb 20, 2009 | 10:36 AM
Steve_L's Avatar
Steve_L
It'll run without it, just make sure your timing is correct and EGR is
working as it should be. I run my Turbo cars with the KS unhooked,
all it does is throw a code during the KOER test...
Steve & the Rockette
'63 F100 4.8L V8
'68 F100 6.4L V8
'72 Capri 2L
'73 Capri 2.6L V6
'73 Capri 5.0L V8
'73 MG B GT 2.6L V6(Ford)
2 '76 Capris, 2.8L V6s
'78 Bronco 7.5L V8
'86 F150 5.0L V8
2 '87 XR4Tis 2.3L Turbo
'01 ZX2 2.0L DOHC
'08 Subaru Imprezza 2.5L DOHC Boxer
Old Feb 21, 2009 | 01:34 PM
MaryfPoppins
Appreciate the help Steve. I will double check the timing.Thanks
