FE Fuel System
Old Feb 12, 2009 | 06:01 PM
footbstar's Avatar
footbstar
FE Fuel System
I am having issues getting fuel to my carburator. I have a new Holley Performer fuel pump and a rebuilt 360FE. It seems as though I'm getting gas to the pump but not the the carb. Does the fuel tank have to be pressurized? Does the fuel cap have to be on? Any thoughts why this is happening?
Old Feb 12, 2009 | 06:18 PM
Bear 45/70's Avatar
Bear 45/70
Never ever have a pressurized fuel tank. It's like having a bomb. However the tank need to be vent so air can get in as the fuel is used. Either loosen the gas cap or remove it and see if your problem goes away. If it does, get a vented gas cap. If it doesn't I would suspect you fuel pump issues.
Old Feb 12, 2009 | 06:50 PM
footbstar's Avatar
footbstar
Right now I have the stock fuel tank, the one behind the seat! Is it a pressurized one? I have a 69 short wide f100. I havent had the cap on or the fuel neck on...
Old Feb 12, 2009 | 08:02 PM
Bear 45/70's Avatar
Bear 45/70
There is no such thing as a pressurized fuel tank. So, no it is not pressurized, not suppose to be and never should be. Especially in the cab of the truck. Where did the idea of a pressurized tank come from? I suspect your fuel pump in bad or you tank is very dirty or rusty and have plugged the fuel pickup in the tank.
stercorarius
Jul 2, 2016 09:52 AM
bigcrunch
Large Truck
Jan 30, 2016 05:59 PM
jeramykt
Feb 16, 2015 06:15 PM
73ferdf250highboy
Aug 13, 2013 06:11 PM
tater_51
WTB - Parts & other
Sep 8, 2010 02:07 AM
