1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
truck leaning
Old 02-12-2009, 04:33 PM
one8thursize1988's Avatar
one8thursize1988
one8thursize1988 is offline
truck leaning
i have a 01 f250 superduty lariat edition v8 5.4 4x4. When the truck is sitting on fairly level ground it is leaning down on the driver side. i had a number of people ask me if i had a broken spring but after inspecting found no broken springs. what could be the problem??
Old 02-12-2009, 05:02 PM
cartmanea's Avatar
cartmanea
cartmanea is offline
Most end up sagging on the driver's side because of the extra weight of the fuel tank and driver on that side. Mine has about 3/4" difference. I've thought about swapping rear springs side-to-side, but that's a lot of work.
Old 02-12-2009, 06:21 PM
conger's Avatar
conger
conger is offline
I think there is a TSB on that issue. Maybe something about leaf springs.
Old 02-12-2009, 09:01 PM
Furian's Avatar
Furian
Furian is offline
You Keep What You Kill
Yes, there is a TSB. My 2005 F350 was lower by 1.75" on the driver's side. Took the truck to the dealership and they installed a 1" shim, wgich was covered under warranty. Anything less than .75" and the dealership will send you on your way.
Here is the TSB:
https://www.ford-trucks.com/tsb/full...hp?tsb=04-23-6
Old 02-12-2009, 09:54 PM
one8thursize1988
thanx. i am going to look into that. maybe take it over to my local dealearship. i bought the truck off of a friend. its got 46000 miles on it and im pretty sure there isn't a warranty on it anymore. if i find that is does need a shim will that be covered by ford or will i have to pay for that??
Old 02-12-2009, 10:18 PM
Furian's Avatar
Furian
Furian is offline
If your warranty has expired then you will have to pay for the shim and labor. Talk to the dealership and see if they will do the repair anyway considering that there is a TSB.
Old 02-12-2009, 10:25 PM
DAVE67FD's Avatar
DAVE67FD
DAVE67FD is offline
I believe most TSB's are only repaired under the 3/36 warranty or some of the premium plans but not sure.
