Some AE numbers
Old Feb 11, 2009 | 06:07 PM
indebt's Avatar
indebt
Some AE numbers
I am typing this from my truck and currently hooked up
ICP 479.89-486.56 psi
ICP duty cycle 9.77 - 10.16%
ICP volts .79
when I try to do a misfire check I only get cyl 1 2 3 5 6 8
why no 4 and 7?
codes = P0475 - P0541 - P0606
and I still cant do a contribution test since my AIH is gone?
Old Feb 11, 2009 | 06:44 PM
F350-6's Avatar
F350-6
What's a misfire check? Sounds like something for spark plugs. Are you referring to the rotational velocity numbers? Is your truck fully warmed up? The engine oil temp has to reach somewhere around 170 deg I believe before the PCM will allow the CCT to be run.
P0475 Exhaust Pressure Control Valve Malfunction
P0541 Manifold Intake Air Heater
P0606 PCM Processor Fault
