self test codes
Old Feb 11, 2009 | 03:35 PM
Ivan M.'s Avatar
Ivan M.
self test codes
did the self test, heres what I got
4 1 /1 4/ 3 3 /1 4 /3 3
what does it meen? thanks for any help
Old Feb 11, 2009 | 08:38 PM
Conanski's Avatar
Conanski
You have an EGR problem, check the whole EGR system including the valve, vacuum lines, sensor and regulator. That covers codes 41 and 33.
14 - Two or more successive erratic Profile Ignition Pickup (PIP) pulses occurred, resulting in a possible engine miss or stall.
This may be an indication of future problems.. depends how bad the motor is running right now. The PIP signal originates inside the distributor and is amplified by the TFI module. As indicated it only takes a couple missed pulses to throw a code so it may not even be very noticable, but if it is the ignition system will need some attention.
See fordfuelinjection.com for all the dirty details on the Ford EFI system.
