86 f150 steering rack
Old Feb 10, 2009 | 10:07 PM
tommy70084's Avatar
tommy70084
does enybody know if u can put a steering rack in 80's f150 some people say u can put a rack from a 91 ford van has enybody done this or know how
Old Feb 10, 2009 | 10:21 PM
Franklin2's Avatar
Franklin2
I don't see how you could. If you look at the way the steering is setup, it is a copy of the twin I beam suspension. So when the suspension goes over a bump in the road, the steering joints ride with it so the wheels will not turn.
For instance, in a vehicle with a rack, the rack and the inner joints will be close to the wide from inner a-arm bushing to inner a-arm bushing, The inner tie rod joint to the outer tie rod joint will be close to the length of the a-arm, so it rides up and down with the a-arm without causing bump steer.
jeffzoot
Aug 18, 2007 10:32 PM
rubiconwarrior
Jul 13, 2007 01:41 PM
cinege
Sep 4, 2005 06:12 AM
Ranger4.0L
Sep 24, 2003 06:23 PM
guinness
Aftermarket Products
May 9, 2001 02:43 PM
