automatic to standard conversion
Old Feb 10, 2009 | 10:03 PM
f1001969mike's Avatar
f1001969mike
hey whats up out there, i have a problem and i was wondering if someone might have the answer for me. i have a 1969 ford f100, its a 2 wheel drive pick-up sporting a 360 v8 with a c6 automatic backing it up.
now, i might have confused people on this question before because i did post a previous thread about it, but anyway i want the c6 out of my truck and i want to put a standard tranny back in.
now my problem lies with the wonderful two piece driveline ford used in their pick-ups that year, i want to put a standard in, i was thinking mabey a t-18 out of a mid 80's pick-up ive found a number of bellhousings that will fit it.
my question is will my driveshaft need to be modified if i use the t-18, i know that it will have to be modified if i go with something like an np-435 ive located one in a truck the same year, but its 4wd and im unsure if the driveshaft off that truck will work after all, it does have a 2 piece driveline haveing a divorced transfer case and all that. can somebody out there help me?
Old Feb 10, 2009 | 10:25 PM
Pro-Street/StateTK's Avatar
Pro-Street/StateTK
f1001969mike
Welcome to (FTE)!
I think a tape measure on each setup bellhousing to tail shaft will be a sure way to know!
p.s. some one may answer this without a tape measure!
Wally Womack
Old Feb 10, 2009 | 10:37 PM
Freightrain's Avatar
Freightrain
Ok, so it's a 2 pc driveshaft, that means you have a long bed. Likely any shaft from a 4 wh drive won't work as it will be too short, especially if it's a divorce case.
I've put toploaders in my trucks, and had to shorten the shaft a couple inches and then use a slip yoke on the front to fit tranny. Doesn't have to slip actually, but works fine. This was my '67 with MX auto. My '69 was a shortbed with C6 and was a once piece shaft. I just found a shaft that would work-got lucky and didnt have to cut one.
You'll likely just have to measure up the std shift tranny(with bellhousing attached) and compare it to your C6. That will tell you what you'll have to come up with. Likely nothing "stock" will work, unless you get a T18 or whatever "truck" 4 spd comes in these trucks and find the driveshaft from one. I like the car versions as I don't need creeper gear.
Old Feb 11, 2009 | 07:44 AM
Redcat Diesel's Avatar
Redcat Diesel
The driveshaft from the 4x4 won't work. What will work is the front section of the of a shaft from a long bed 2wd truck with a 4 speed. Doesn't matter if it's a T18 or NP435. The length of the front section is the same on 67 - 79 2wd trucks with the 4 speed option that used a 2 piece shaft. The tube diameter is larger on some of the later ones but unless you are planning big HP it won't be a problem.
